BX2660 meets BX2200
/ BX2660 meets BX2200 #1
SeymourBota
Central Vermont
Kubota B2410, BX2200
It's amazing how much has come full circle between these machines-
metal hood and fenders
oil, air, fuel and hydro filters match
almost exactly the same length with FEL
Gotta love what they have improved, though!!!
The 2200 has 650 hours and goes into semi-retirement with only about .25 acre to mow at its new location.
First, it's time for the snowblower, though!!
/ BX2660 meets BX2200 #2
*The 2200 has 650 hours and goes into semi-retirement with only about .25 acre to mow at its new location.
What do you need or use 2 FELs for?
Do you still have the B2410?
I was looking at the B2410 before discovering the BX23.
/ BX2660 meets BX2200 #3
Seriously? Of all the folks on this planet to ask this question, it has to be you? Owner of 3 nearly identical tractors? The rest of us will simply state 'resale'.
To paraphrase Senator Phil Graham: 'I got more tractors than I need, but not as many as I want'!!
The 2200 is being semi-retired to secondary service at the lake, along with the 2410.
Only the 2660 will be at my home property.
That 2200 FEL won't see too much use from now on, but it will be an asset when I eventually sell it.
/ BX2660 meets BX2200 #8
I thought he made it clear the older BX would be semi retired on a different property. Two properties, two tractors. Sounds good to me.
/ BX2660 meets BX2200 #10
Lbrown59,
It's not that you have too many tractors, I think you don't have enough properties.
Only problem is, for each property you need attachments. Man, you would have so many things listed on your signature, it would take up the screen.
/ BX2660 meets BX2200 #11
Lbrown59,
*It's not that you have too many tractors, I think you don't have enough properties.
*I'm starting to think not to many tractors but to few acres too.
/ BX2660 meets BX2200 #12
OK LBrown.
Admit it. How many times have you got on a tractor, gone to the other side of the property and realized, you're on the wrong one with the wrong implement. Come on, admit it, you're amongst friends.
/ BX2660 meets BX2200 #13
OK LBrown.
Funney you should mention this.:D
I was just telling my wife a couple of days ago that sometimes I have to stop and think about what tractor I'm using.
/ BX2660 meets BX2200 #17
LBrown59
Is the 59 in your user name your BX target for ownership or are you going for a Genis record? LOL
By the way thank you for looking at your skid shoe adjustment for me and were those bottom washers apposing each other or laying flat together?
/ BX2660 meets BX2200 #18
LBrown59
The year I graduated from High School .
50 th class renunion coming up next year .
I will have to check on the washers again.
/ BX2660 meets BX2200 #19
Is there a big difference between the 2660 and the 2350? I'm new to this and am trying to figure out how much power I need. 4 acres, 3.5 wooded, .5 landscaped, I wan to do some clearing, about another .5 acre, and the rest of time for snow removal and mowing, and also want a loader for odd jobs. Don't know if I need the extra 2.5 hp, or the $1000 difference more.:D:D
/ BX2660 meets BX2200 #20
LBrown59
Picture a saucer setting on the table.
Now take another saucer and turn it upside down and place it on top of the one on the table .
This is how you position the washers from top to bottom.
Basically the first washer is right side up like the saucer setting on the table then you reverse every other washer .
Did this help you any?
L . B .
Briggs and Stratton Generator (A65579)
Briggs and...
Superior Broom DT80J Street Sweeper (A65579)
Superior Broom...
GOOSENECK SPOOL TRAILER (A65643)
GOOSENECK SPOOL...
Deutz DX140 Tractor (A66285)
Deutz DX140...
2016 Cadillac CTS Sedan (A64557)
2016 Cadillac CTS...
10in. Auger Bit (A65640)
10in. Auger Bit...
