MF 1523 Tractor steps. Ideas welcome.
   / MF 1523 Tractor steps. Ideas welcome. #1
WilliamBos
Super Member
Innisfil, Ontario, Canada
MF 1635 12x12 Powershuttle
Hi All,
Next little project for us is fab & Install steps on our 1523. We are thinking of welding some flat bar, and painting it, and then bolting it on, but wondered what others have used.
Also, any pics of mounting them are welcome from all colours, especially MF 1500 series owners.
   / MF 1523 Tractor steps. Ideas welcome. #2
Hi All,
Hi there I have a JD 2320, I also wanted a step, so I looked around and found one that was on a larger ag tractor, it is all made of stamped steel with teeth on the tread steps, so that if your feet are muddy or you are blowing snow it is not slippery, its is about 15 inches long and 8 inches wide, best of all its only about 25$ at your local John Deere Dealer. I am not sure of the part number but If you want I can find out. My buddy owns a Kubota and is alway giving me a hard time about my driving a green machine. But after looking at my step, he went out and bought 2 for himself, and sandblasted them to rough them up then painted then orange. You can't build this step for the money and time involved. You might have to fabricate a way to mount it but that should not be a problem....Let me know!
   / MF 1523 Tractor steps. Ideas welcome. #3
I actually removed the right-hand step from my Branson. I never use it due to the configuration of the operator's platform, and the loader controls (as a big-guy, I don't contort too well).
I'm mounting a .50 cal ammo box in it's place as my tractor tool-box. The opposite step flexed a bit when I stepped on it, so I welded a piece of angle from it back to the plate holding the fuel tank for extra support, and dabbed a bit of Herculiner on the metal between the step and the rubber platform mat, for added slip resistance.
I don't miss the right-hand step, but wouldn't want a tractor without any...
Lunk
If you could get that part#, that would be appreciated.
   / MF 1523 Tractor steps. Ideas welcome. #5
Sorry I took so long to get back to you , the step I talked about goes on a John Deere 3320 compact tractor, the part number is R215053 and the price is $31.08 Hope this helps:)
   / MF 1523 Tractor steps. Ideas welcome. #6
I haven't built any tractor steps, as mine all have some sort of factory steps. I did get a request from my sister, who never asks for anything, if I could make it easier for her to get into her van. I had a couple left overs from when the shop I worked at made fire engine parts, so I modified one, added an aluminum 2x2 and a little bit of welding and sent it to her. I did tell her to purchase a lock so it didn't disappear, being made out of solid aluminum. Attached picture for your viewing.
David from jax
   / MF 1523 Tractor steps. Ideas welcome. #7
I used 2"X1/4" flat hot roll steel. Bolted to tractor floor board. Made one
for each side. Used actyene torch to heat metal for bending. Would
post picture, but don't know how. Pretty easy to make.
elad
JOHN DEERE 4066R LOT NUMBER 23 (A53084)
JOHN DEERE 4066R...
Booster Cables (A55852)
Booster Cables...
2016 Ford F-150 Ext. Cab Pickup Truck (A55852)
2016 Ford F-150...
1659 (A57192)
1659 (A57192)
2022 Big Tex 22GN-35BK+5MR 40ft T/A Gooseneck Equipment Trailer (A51691)
2022 Big Tex...
2022 JOHN DEERE 6120M LOT NUMBER 191 (A53084)
2022 JOHN DEERE...
