62C deck with mulching kit
/ 62C deck with mulching kit #1
CFHartman
Keyser WV
John Deer 2210
Has anyone used the 62C deck with the mulching kit. I have a 2210 with the 62C deck. Last year I bought a set of Gator blades for it. I was not impressed at all. I ended up raking my leaves and then grinding them with my Troy Built Chipper shredder. Which is the way I have been doing it for years. I'm getting older and not enjoying raking leaves anymore. I'm looking for info from anyone that has used the mulching kit with there mower on leaves. It getting expansive buying and finding out for yourself that it don't always work for you like they say it does. With the Gator blades I had to keep running over the same row and moving it 12 or more times before it disappeared.
Thanks for any input and enlighten anyone can offer
Charlie
/ 62C deck with mulching kit #2
*I'm getting older and not enjoying raking leaves anymore. I'm looking for info from anyone that has used the mulching kit with there mower on leaves. It getting expansive buying and finding out for yourself that it don't always work for you like they say it does. With the Gator blades I had to keep running over the same row and moving it 12 or more times before it disappeared.
Charlie
I just let em lay here.
Been here on this place for 42 years and it's always worked just fine.
/ 62C deck with mulching kit #3
I have the mulching kit installed on the 62" deck on my 2305. I have used it for two mowing seasons and would highly recommend it. During the grass growing season, I set my mower high to keep the weeds down. When the leaves come down, I drop the mower and run a little slower and it cuts the leaves up and I never rake anymore. If the leaves are large and heavy, I might have to go over them a second time. I try to mow when the leaves are dry since they mulch better then.
Thank you Gary. That is what I was hopeing to hear.
Charlie
/ 62C deck with mulching kit #5
When multching, its very important that the grass or leaves are dry. Otherwise, you plug up the deck and create work........
2014 Ford Escape 4WD SUV (A61574)
2014 Ford Escape...
2005 Butler pole trailer (A62679)
2005 Butler pole...
WACKER NEUSON LIGHT TOWER (A63569)
WACKER NEUSON...
2011 WESTERN STAR  4900SA  SLEEPER (A63569)
2011 WESTERN STAR...
2009 Arco Trailer 6,000 Gallon T/A Tank Trailer (A61568)
2009 Arco Trailer...
2016 Deere 180G (A60462)
2016 Deere 180G...
