48 SC
/ 48 SC #1
toycruiser
i won a 1948 case sc in a raffle an don't see where to check the oil.
is it missing a dip stick or a plug to remove to see if the level is correct?
thanks for any help.
/ 48 SC
i didn't see one.it has rained here for the last few days,
when the weather clears up i will look again..
would that be in the oil pan?
/ 48 SC #4
There are two small plugs on oil pan left side. highest one would be oil full,lower plug is one quart low. Add oil until it just starts to come out of higher plug. Hope this helps you.
/ 48 SC
Thanks James.i found the plugs you are talking about.
the level is good to go.
plan to put it in the oct parade an the cotton festival.
thanks to all..
2015 FREIGHLTLINER CASCADIA 125 6X4 T/A SLEEPER TRUCK TRACTOR (A67147)
2015 FREIGHLTLINER...
Volvo 10ft Loader Rake Attachment (A64553)
Volvo 10ft Loader...
2022 JOHN DEERE 350G LC EXCAVATOR (A65053)
2022 JOHN DEERE...
JCB 3TS-8T TELESKID (A65053)
JCB 3TS-8T...
LOT OF YETTER SHARK TOOTH TRASH WHEEL UNIT MOUNTED (A64278)
LOT OF YETTER...
2018 Freightliner M2 106 20Ft. Reefer Box Truck (A64194)
2018 Freightliner...
