What lube in front axle?
   / What lube in front axle? #1
BJN644
Maine
Kioti CK35 HST
Some of the recent post have made me think about my front axle a little more. It's almost first service time, the manual says to use hydraulic or gear oil in the front axle. There is quite a viscosity difference between hydraulic and gear lube, just wondering what everyone is using in their tractor.
   / What lube in front axle? #3
When I did my first service the dealer told me to use the same fluid in the front end that I used in the rear. So for the last 700 hours I've used trans/hyd fluid in the front axel as well as the rest of the tractor.
   / What lube in front axle? #4
90W is I believe what is called for. That's what I have been using and it is what my dealer provided when I asked.
   / What lube in front axle? #5
I use Mobil 1, 75/90W synthetic in mine. I use my tractor for snow removal and want lubricants with the lowest available pour points, so as to get the maximum lubricity possible. The little extra it costs for the drain intervals involved is of no significant consequence and if you've ever seen someone attempt to pour 90W gear lube at -10*F:eek:, you know what I mean;)
   / What lube in front axle? #6
Figured I'd harp in here too. My front end was leaking and I use it too much to lay it up during the season. I was putting in 90 weight gear oil but it would leak out and stain the garage floor and the trailer deck.
I spoke with the John Deere dealer and he suggested (as a interim fix) to fill it with corn head grease. It liquefies under extreme hot conditions and stays like loose grease when cool. I pumped it into the front end and have used it for the past two years :eek:.
Maybe I'll get around to replacing the seals next year or maybe not :rolleyes:.
The cold temps. here in Maine is one reason I was leaning towards the hydraulic fluid, just wanted to hear what others were using. Hoping one of the dealers would chime in and say what they use, like I said originally the manual says gear or hydraulic, unless I'm reading it wrong.
   / What lube in front axle? #8
There's no question a universal tractor fluid will work and maintain the warranty, but I'm looking for something more substantial in an area that is subject to significant stress(turning and driving). The UTF works in the(common sump) transmission/differential/hydraulic area quite well, but if I could upgrade the performance in that area significantly with a synthetic at a reasonable cost, I would. The small investment in the front end involving a synthetic lubricant is a "no-brainer" IMHO.
Stopped by my dealer today, this is exactly what they told me. They said the thinner hydraulic oil lubricates better in cold weather than the thicker gear oil, which is what I was thinking too.
2006 FREIGHTLINER COLUMBIA 120 (A55745)
2006 FREIGHTLINER...
2001 BIG TEX GOOSENECK (A55745)
2001 BIG TEX...
UNUSED FUTURE FT-FB30 HYD FELLER BUNCHER (A52706)
UNUSED FUTURE...
2024 Bobcat T770 (A53317)
2024 Bobcat T770...
2005 Dodge Grand Caravan Van (A55853)
2005 Dodge Grand...
2025 Swict 84in Bucket Skid Steer Attachment (A53421)
2025 Swict 84in...
