lub points
/ lub points #1
jimwillis
i have a slt 1550 i know that the wheels and axle have lub points and the spindels for the mowing deck. are the lub points for the spindels below the deck or on the top. i assume they are some more points. can some one tell me where they are
thanks
/ lub points #2
the spindle fittings are under the deck. I grease mine when i have the blades off for touch up sharpening.
/ lub points #3
There is also a fitting on top of the idler pulley bracket at the pivot point.
When greasing the spindle bearings there is a weep hole in the center of the housing. I have an air operated grease gun and pumped a few oz of grease out this hole while watching for it to come out the top or bottom on the first one.
It is best to remove the deck and turn over to grease. It's tricky to get the belt back on. There is a square hole in the idler bracket that a 3/8" ratchet/breaker bar fits in so you can pull the pulley back to put the belt back on. You just have to stand on your head to do this!
John Deere 8330 Tractor (A64047)
John Deere 8330...
Arrow Quip EF8 Two Bow Alley Kit (A64047)
Arrow Quip EF8 Two...
2025 48in. Farm Jack (A61567)
2025 48in. Farm...
2019 Ligchine Spiderscreed Concrete Screed (A59228)
2019 Ligchine...
12ft Cattle Panels (A64047)
12ft Cattle Panels...
2007 International 4300 Box Truck, VIN # 1HTMMAAL27H513415 (A61165)
2007 International...
