Favorite tools-any odd tools you find really usefull?
/ Favorite tools-any odd tools you find really usefull? #1
Sackett2
Eugene, Oregon
Montana 4344HST
Mine is the Power Probe. powerprobe
You attach it to the battery of the vehicle you are working on, touch the tip to a hot and it shows red (with tone) a ground and it shows green (with a different tone)
Rock the switch forward and battery voltage is at the tip, back and ground is at the tip.
It has a ground clip so you can activate a component
Power Probe 1 is led only
Power Probe II has led and tones
Power Probe 1 has led, tones and a voltage meter
An example on how I use it: had a car with tail lights inop. Hooked the probe up and pulled the left assy out. touched it to hot side of the bulb, red light=good power. touched it to ground side, nothing. rocked the switch back to ground the lights lit up. Repaired the broken ground.
on spade fuses i just walk down the rows of fuses looking for power on each side or a good ground on each side.
a great tool, around 100 dollars.
I own two p/p 1's and one p/p 3
/ Favorite tools-any odd tools you find really usefull? #2
- grafting knife for any work with wood
also a habit to use an axe instead of framing hammer - like this one.
/ Favorite tools-any odd tools you find really usefull? #3
/ Favorite tools-any odd tools you find really usefull? #4
Paul, you really do some neat work. That's a fine look cart for that welder, and I looked at some of your other work, too. Really work to be proud of.
/ Favorite tools-any odd tools you find really usefull? #5
A short handle 2 lb hammer. You take a normal hammer and cut off about 5"-6" of the wood handle. It fits in more tight spaces than you can think of. A mechanic friend of mine from 25 years ago, accidentally broke his hammer handle and said the shorten handle was the most useful hammer he has ever used. I, later, cut my handle and it is the most used tool I own. It increases your accuracy too, for hitting punches, chisels or tapping in roll pins, etc. Just buy a cheap $5 hammer and try it. Actually, grap the handle close to the head, wear it feels comfortable, then saw the handle off right behind your hand.
/ Favorite tools-any odd tools you find really usefull? #6
My favorite is my 4 lb hammer. It seems that there's always something that needs coaxing. And with a heavy head, you don't need to take a big swing.
I bought an extra one that I leave outside. Let it rust, it still works fine.
/ Favorite tools-any odd tools you find really usefull? #7
Gotta go with the standard 1lb hammer, and the channel-locks... the pry bar is indespensible when it is...
/ Favorite tools-any odd tools you find really usefull? #8
Hate to pile on but I have to go with the short-handled 2 lb hammer. If you need it there is no substitute.
Almost went with the jacknife, prybar, adjustible wrench or screwdriver. Can't get by without those either.
But love that hammer. Mine happens to be Japanese, I think, from maybe 20 years ago. Looks it's age but very well cared for.
/ Favorite tools-any odd tools you find really usefull? #9
Blue Tipped Wrench. I think it falls into the "get a bigger hammer category". No more problems with seized bolts for sure :D
/ Favorite tools-any odd tools you find really usefull? #10
Thought about that for a little while. The tool I find most often in my hand is my Leatherman "Super" that I bought many years ago. Have used it lots and it is still in good working condition. The nylon belt holster is nearly worn out though.
Part of the reason for it being most often in my hand is that it is always right there within easy reach. It might not be the very best tool for the job but still much better than no tool.
/ Favorite tools-any odd tools you find really usefull? #11
I'm not sure I have a favorite tool. I have some I use lots but just to name one would be a good 3/8 drive socket set. :D:D
Then again I really like my chain saws when they make noise so???:D:D
Final vote will be all my tools and if I'm forced to pick just one it would the wooden mallet I turned myself from maple cut out at "The Farm".:) :)
/ Favorite tools-any odd tools you find really usefull? #12
Pulp hook. If you handle logs or firewood, makes picking up and moving the wood much easier.
/ Favorite tools-any odd tools you find really usefull? #13
Brandoro I知 with you. Mine is Gerber Recoil. It痴 with me all the time when I知 not in my Sunday best.
/ Favorite tools-any odd tools you find really usefull? #14
Brando I'm with you. Mine is Gerber Recoil. It's with me all the time when I'm not in my Sunday best.
/ Favorite tools-any odd tools you find really usefull? #15
Someone told me once at a flea market that you called that a "chub"? Dunno' about that for sure but I have a 2lb hammer shaped like a sledge with a short handle that I bought that day and indeed it is handy.
As far as favorites, that is a tough one for a tool junkie. I picked up a Hitachi 14V Lithium Ion impact driver a few months ago and I find myself using that tool a lot. It is a lot more compact than my Milwaukee 18V driver/drill which is now mainly used for drilling only.
/ Favorite tools-any odd tools you find really usefull? #16
A blue B&D adjustable workbench. (One of those things with the two wind-in handles). When i received it as a gift about 30 years ago I thought it would probably sit in the corner and never get used. But its now had an amazing amount of use. Its splattered in paint, full of drill holes, had bits accidently cut off, and is generally a mess but its still works just fine. I've built decks, sheds, pergolas and boats with it. For outdoor woodworking its invaluable. But like any tool you have to get in the habit of actually bringing it out and USING it to appreciate how handy it is.
/ Favorite tools-any odd tools you find really usefull? #17
with the way you guys like hammers as your favorite tool, i don't know if i want you working on anything of mine!:eek::eek::eek::D
man, that's a tough one!
/ Favorite tools-any odd tools you find really usefull? #18
Years ago, a Ridgid Tool distributor gave me a 6" pipe wrench. That thing has proven to be handier'n a shirt pocket over the years.
/ Favorite tools-any odd tools you find really usefull? #20
Those also work as mini hammers. Was it an aluminum one?:D
Forged steel. I've got an aluminum Ridgid 24" "non sparking" pipe wrench under the seat of the truck.
Why is everyone on here so obsessed with HAMMERS???? ;) :eek:
Year: 2016 Make: Ford Model: Explorer Vehicle Type: Multipurpose Vehicle (MPV) Mileage: Plate: Body (A55853)
Year: 2016 Make...
2014 Jeep Compass SUV (A61569)
2014 Jeep Compass...
2019 Ford F-150 4x4 Crew Cab Pickup Truck (A60460)
2019 Ford F-150...
2014 FREIGHTLINER CASCADIA T/A 6X4 SLEEPER TRUCK TRACTOR (A59906)
2014 FREIGHTLINER...
2022 KAUFMAN 4X2 2 CAR TILT GOOSENECK TRAILER (A59906)
2022 KAUFMAN 4X2 2...
2018 FREIGHTLINER CASCADIA 125 6X4 T/A SLEEPER TRUCK TRACTOR (A59908)
2018 FREIGHTLINER...
