What to do with old Bush hog gearbox?
   / What to do with old Bush hog gearbox? #11
What is the gear ratio of a bush-hog gearbox? It could be 1:1, or 1;2, or maybe 1:3
It's probably about 1:2. Bush Hog pitches a blade tip speed of 14,800 fpm on the 48" mower. A 2 foot radius equals about a 12.5 foot circumfrence. This means that to hit 14,800 fpm the blade has to go about 1170 rpm. On a 540 PTO that's just about a 1:2 gear ratio.
Of course even if you only had a 6" diameter drive attached to the output of the gearbox for a trencher, that's still 1850 fpm for the trencher blade to be moving. How fast do most trenchers blades move?
   / What to do with old Bush hog gearbox? #13
My first rotary trencher I made was from a 1to1 cotton picker spindle box. with a 2inch blade. works real good needs tiller teeth though. My second had offset teeth and from chipper blades and they used a 1 to 2 gear box and mor teeth it works better the faster it goes.
   / What to do with old Bush hog gearbox? #14
I think Sandman2234 has some pictures of one he made.
   / What to do with old Bush hog gearbox? #15
I am fixing to trade a 6' bush hog for a finish mower, and really wish you lived closer, because I would love to have one that I could rebuild the deck on, to replace the bush hog I am fixing to get rid of. I need a bush hog, but the finish mower has a paying job coming with it, so I figure I better take it...
David from jax
David,
If you feel like driving West on I-10 about 3 hours I will give you a 6ft Howse cutter that needs work. It needs some deck repair, a new gear box, stump jumper, and blades.......it's free for the taking!
PM if interested.
Stu
   / What to do with old Bush hog gearbox? #16
David,
PM if interested.
Stu
needs deck repair,new gear box, stump jumper and blades
lol what else is left, the tail wheel?? sounds like a project
   / What to do with old Bush hog gearbox? #18
Possibly a stump grinder out of the gearbox and 3 point parts...
   / What to do with old Bush hog gearbox? #19
Sure would like to see one of the home made trenchers. I could use something like that for sure.
   / What to do with old Bush hog gearbox? #20
For sure keep it.. even if it is only a spare.. toherwasie.. as the others have mentioned.. you could build lots of things with it.. maybee even a auger.. etc..
soundguy
TORO GREENS MOWER (A56857)
TORO GREENS MOWER...
Deere 310SK (A57148)
Flatbed Truck (A55973)
2007 Ford F-150 Ext. Cab Pickup Truck (A59230)
2007 Ford F-150...
2020 CATERPILLAR 303.5E2 CR EXCAVATOR (A60429)
2020 CATERPILLAR...
2860 (A56857)
2860 (A56857)
