hydraulic failure
/ hydraulic failure #1
thomaswilliam
walnut cove ,nc
century-2035
The front loader on my Century 2535 failed to operate yesterday. At the same time, the the rear lift also failed to operate.
I checked the fluid and it was ok.
I had not used the tractor for about two weeks.
Any ideas how to activate this joy stick?
My dealer went belly up. The nearest dealer is miles away from me.
I live in Walnut Cove, nc. This is about half way between Greensboro and Winston Salem , NC.
Any help or suggestions will be greatly appreciated. I am not a mechanic. I have been unable to get a copy of the manuel 948882.
2002 with 391 hrs.
tcheek5682@aol.com
/ hydraulic failure #2
Pump failure, filter restriction? Is there a whining noise like that of a power steering pump with no fluid? Has the tractor had its 50 hour service. I've heard that the screen in the sump can have a substantial restriction due to metal shavings. I UNDERSTAND that two screens exist in addition to the spin-on filter, one in the sump of the trans-axle, and one just prior to the inlet of the pump. The joystick operation is all mechanical and if the knob under your seat is turned to "fast" you are probably not getting any fluid movement.
/ hydraulic failure
Today I will replace the spin on filter. The fluid has less than 30 hours on it. Can I remove and clean the sump filter with our the oil running out of the entire system?
thanks
tom
/ hydraulic failure #4
thanks
tom
No. Go to the store and buy 3 cheap 5 gal gas cans.
/ hydraulic failure #6
Just a thought, are there quick connect couplers to feed the loader valve? Make sure they're hooked up.
/ hydraulic failure
yes, everything is connected. I did add a gallon of fluid. A Branson dealer in Greensboro has a new filter for me and i will get that monday just to be sure the one on the tractor is not stopped up. I want to learn something about a "hydraulic suction screen" Maybe that has something to do with this?
I just hope this does not turn out to be a pump or cluch disk problem. That's big bucks?
Thank you for your suggestions and help.
tom
/ hydraulic failure #8
The suction screen cover is located on the right side of the tractor (looking from rear to front) behind the fender. It is held in place with 3 10mm bolts. The is also a larger bolt/plug in the center that is possibly a drain? Be careful removing this as it seals with an O ring. You will have to drain the hydro oil to get the screen out. Once removed rinse any debris away with diesel or kerosene. The screen is reusable and can be placed back in the tractor after cleaning.
/ hydraulic failure #9
On the bottom of the rear axle, to the very front, just under the drive shaft is a drain plug. I couldn't find this until after making a big mess trying to catch the fluid by taking the filter loose.
On my 3510 Branson it was a lot easier to take the right rear tire and wheel off to get to the screen area. Just use a jack stand for safety.
If your oil still looks good/clean and smells good (no burnt smell) I would re-use it. I took the first 50 hour service oil, checked it and re-used it in an old Clark Forklift that I have. (Much better than the oil/water that was in it!)
The first hydraulic oil change is more critical than others because it will have break in particles but the filter and screen should catch them..
/ hydraulic failure
I hope to do these tasks Tuesday or Wednesday. I will get the spin on filter on Monday.
Thanks fellows concerning the suction screen. No doubt that saved me a lot of fluid which could probably be used for other purposes.
tomc
/ hydraulic failure
This AM. I replaced the spin on filter. Started the motor--no action from either the FEL or the bush hog. Shut down the engine. Removed the bottom high pressure hose from the FEL, started the engine--no fluid at all from the hose !
It looks like the pump is not operating. The dealer said a new one would cost somewhere about four hundred dollars. He said the pump was not real hard to remove. 4-bolts and slide it off and inspect the spline shaft which powers the pump. If that is in good condition, replace the pump with the new one. That should solve my problem ?
Thanks for any comments.
tom
/ hydraulic failure #12
tom
Now, on the 3520 I seem to remember the manual showing a tiny in line screen/filter just before the hydro pump. Maybe they are the same, also, make sure you check the internal screen in the trans axle area.
/ hydraulic failure #13
One more possibility -
Our Branson 3510 came with the backhoe mounted and lived that way the first two years of its life. The first time I removed the backhoe and reconnected the 3-point the hydraulics collapsed. No flow. I changed the filter, cleaned the screen, etc. Still no flow. I then trailed it into our local independent dealer. His guy put the gauges to it and within an hour found the filter base was plugged - completely packed with trash. I'm guessing this stuff collected in the 3-point hose over the first two years of use and blew out in one big chunk when the 3-point was recommisioned.
My only regret was not trailing it in sooner. Cost me $65 for the hour of his time. I spent nearly that on fluid and filters and I'll never get the hours back.
/ hydraulic failure
update on century 2535. Worse case scenario. Female drive gear stripped. Looks like a bearing might have failed and caused this malfunction. However, my dealer said this is a Seven hundred and fifty dollar repair job if nothing else has failed>
More later
tom
/ hydraulic failure #15
I was HOPING to see some progress.
Was it just that PTO gear at the front of the engine ?
Was there other damage ? (I hope NOT)
How about root cause ?
I assume you got the shop manual by now and that your local Branson dealer/parts guy came through with the gear.
PS Pictures ?
\R
/ hydraulic failure
Century 2535 repaired and back in the field. The gear which drives the steering pump and the hydro was stripped on the hydro side. Took nearly 4 weeks to get the $135.00 gear at the Branson dealer.
Job time- 6 hours down-8 hours up. [this includes complete fluid and motor oil change]
Working fine, except for some reason, when we started the engine, the idle speed was higher than before we did the gear work. Guess i will learn something else new here--how to adjust the idle speed. I don't find that addressed in the shop manual i have.
Thanks to all the helpful comments here, really appreciated.
tom
tcheek5682@aol.com
/ hydraulic failure #17
That's great news and didn't cost a whole lot.
tom
tcheek5682@aol.com
I seem to remember seeing something about this in one of the manuals. It might have been the operators manual. I'll go have a look and post back if I find it.
2003 Ford E-450 Super Duty Passenger Bus (A61573)
2003 Ford E-450...
2015 Mack CXU613 Tri-Axle Day Cab Truck Tractor (A64194)
2015 Mack CXU613...
KALMAR AC P50BX-PS WAREHOUSE FORKLIFT (A64276)
KALMAR AC P50BX-PS...
2012 GMC Sierra 1500 4x4 Crew Cab Pickup Truck (A64556)
2012 GMC Sierra...
2022 JOHN DEERE 333G SKID STEER (A65053)
2022 JOHN DEERE...
REEL RAIN HARD HOSE TRAVELER (A64278)
REEL RAIN HARD...
