Hydraulic system bleeding
/ Hydraulic system bleeding #1
dirtrod
I’ve just added 30 feet of hydraulic line and a new piston to my tractors hydraulics and would like to know
the correct / safe way to bleed the air from the new additions.
/ Hydraulic system bleeding #2
Just operate all your controls. Raise the rear lift up and down and the same with the loader. By doing so it will self purge.
/ Hydraulic system bleeding #3
I agree with JerryG.
/ Hydraulic system bleeding #4
I am replacing a damaged hydraulic line on a Bush Hog 2045. Does the same advice hold true? I'm new to this stuff and have to ask a really dumb question - but - here goes... where would someone hide the tank? I'm going out to look again...
/ Hydraulic system bleeding #5
Yes, Moot, same applies to you. Just operate the control to cycle the cylinder and the air will bleed out. As far as the tank, do you mean on your tractor or what? More info needed please...
/ Hydraulic system bleeding #6
Yes, I guess it would be on/part of the Kubota L3010. I traced all the lines on the loader and it looks to me like all the fluid is supplied from the rear PTO housing? There is a red 'oil' fill cap and a small glass site gauge. Is that it?
/ Hydraulic system bleeding #7
Yes, that is correct. The oil "tank" is the rear housing. To check the fluid level make sure the FEL and 3PH is fully lowered, the oil should be about 1/2 way in the sight glass.
I guess you do not have a manual for your tractor?
/ Hydraulic system bleeding #8
No manual... I'm still looking for one.
Thanks for the info. Out of curiosity, where does the air go? Should I leave the 'oil' cap loose? Also, I guess I'm going to have to replace some fluid. I believe it has the Kubota Super UDT. Do I have to use that?
/ Hydraulic system bleeding #9
The air get pushed pout of the cylinder seals or ends up back in the tank where it dissipates. There is no need to leave the cap open.
As far as what type of fluid-I can't answer that as a JD guy...but if you use the search feature you will find your answer I'm sure.
/ Hydraulic system bleeding #10
Thank you again. Got the new hose and am up and running.
One more question...
Should the tractor be running to check the fluid level?
/ Hydraulic system bleeding #11
No, the tractor should not be running.
2018 Ford Escape Multipurpose Vehicle (MPV), VIN # 1FMCU0F70JUB03642 (A61165)
2018 Ford Escape...
2010 FORD F-150 XL CREW CAB TRUCK (A62130)
2010 FORD F-150 XL...
NEW HOLLAND TS115A TRACTOR (A62130)
NEW HOLLAND TS115A...
New Holland 5030 Tractor (A61166)
New Holland 5030...
CAT CB-334E Smooth Drum Roller (A61166)
CAT CB-334E Smooth...
2022 WABASH DVSVHPC 53X102 T/A DRY VAN TRAILER (A59909)
2022 WABASH...
