Very Deep Plowing...Why?
/ Very Deep Plowing...Why? #1
JDeerekid
P-Town, Upstate New York
Montana 4340C w/Loader, JD GX345 w/54in. mower
I was just messing around on YouTube and came across some videos that had some huge 2 bottom plow looking thing plowing using 2 or more tractors. What is the purpose for this? Why not use a regular plow with multiple bottoms and use 1 tractor. Does it still leave a hardpan bottom. Is it a repacement for subsoilers or rippers? Still looks pretty cool.:D Here are some links to a couple.
YouTube - Deepplowing Fleovpolder
YouTube - diepploegen met fendt
YouTube - Deepplowing Flevopolder
/ Very Deep Plowing...Why? #2
I think I read they do this on flood ground to bury the possible contaminants,, but I could be mistaken with all the stuff I read
/ Very Deep Plowing...Why? #3
Interesting.
Here in the Sacramento Valley deep subsoiling is done with really big Caterpillar tractors to break up the hardpan and prepare the soil for orchards. As far as I know, that deep tilling with moldboard plows shown in the videos isn't used around here.
/ Very Deep Plowing...Why? #4
Google "deep tillage" and you get answerer to why its done and where and what type of benefits result.:D
/ Very Deep Plowing...Why? #5
There are three reasons for doing this:
1. contamination:
The first was already assumed, for growing flowerbulbs they want to change soil every year: the full layer of soil is buried 2 feet deep before planting, so all diseases die during the next growing season.
2. prior to grading a field:
on high spots, the topsoil is buried under subsoil. Then tractor drawn scrapers move that subsoil to lower areas. when scraping is done, they use the plough again, to put the subsoil back down where it belongs, and get the topsoil from under the fill. This way you can level a field without disturbing the soil profile: It prevents that you remove all topsoil from the high parts, and make the layer of topsoil even thicker on the low muddy patches.
It may sound odd, but its the only way to keep an even layer of topsoil when levelling a field with more than a foot of level differences.
3. To mix various soil types
Some soil mixtures are better than the individual layers: the Dutch soil is partly washed in from the sea, partly washed in from the rivers from the Alps, partly rotten plant material (peat) and partly virgin clay soil by damming a part of the sea and pumping out 5 meters (16 feet) of water.
Because our country is river delta mostly, soils occur in all fashions: peat on top of a clay layer, (a pool with lots of plants that rotted away over the years) sand on clay, (foreign sand washed over the clay by natural water flows) sand on peat (sand washed over peat soil)
Pure peat on its own isnt fertile at all: thats why they mix it with a clay or sand subsoil, this way it will have a better Ph, and be less prone to compaction and water pooling.
What is seen in the video, is on a former seabottom: the clay soil is very fertile but very hard on equipment, prone to slump, and there is a lot of soil tarr on root crops like potatoes and sugar beet.
Then it pays to mix some sand subsoil through the layer of clay.
I worked a short while for the company that runs the Cameco and Fendt with that deep plough.
Or actually ploughS because they dont just have one, but have them in steps of 30 cm working depth:2 and 3 foot working depth 2 furrow ploughs, 4 / 5 and 6 1/2 foot 1 furrow ploughs.
They are specialists and can pick the right plough for the job, like an artist picks the right brush for the painting ;)
Their fleet of extreme ploughs is partially "home" made (well, they are a very big company with a professional workshop) and some are made by Panter special ploughs: Panter Ploegen
The Cameco was purpose built for this operation, and weighs 23 ton. Therefor, it isnt used on peat soils, they are afraid that the soil will swallow it some day. :D
Then they run 3 Fendts, of 180, 230 and 260 hp. Individual tractors are easier to extract from the bog, if the soil decides to swallow one of them.
the 3pt hitch of the Fendt carrying the plough is reinforced: It doesnt have the quick tach lower links because the hooks bend open: It doesnt have a normal toplink, but a solid bar of steel. The short arms to which the 3pt lift cylinders attach, is connected outside the lift cover by a U shaped arm, torched out of solid steel of 4 inch thick: when tipping the 2 way plough, the momentum is so high that the original torsion shaft of the Fendt linkage snaps.
the link arm connection to the rear axle has been modified: not only reinforced, but it also has a tow eye: In the 80's Van Werven has ripped 1 or 2 Fendts in two with the Cameco: Since then, they attach the chain not to the tractor, but to this modified lower link arm attachment bar. (also torched out of solid steel)
What you see on the front of the tractor, is only a large hoop, to guide the cable from underneath the tractor.
The old truck tire which is inbetween the chains that attach Fendt and Cameco to absorb the shocks, lasts only a couple of days. Next to Ag work, Van Werven has a big trucking and container fleet, so pulling the tire apart is the least worry ;)
They told me they ran a 570 hp Challenger tracked. Because of the big side incline of the deep furrow, the (any) tractor tends to pull into the furrow into the ploughed land. The challenger could easily pull the plough alone, but the steering hydraulics ran hot because they constantly had to adjust.
This company is the only specialist in the world, because it is mostly done in Holland because of our funny soil that was washed in from sea and rivers, or built up from rotten plants in wetlands.
Panter incidentially also exports ploughs for forests, planting new forests as well as reclaiming existing forests.
They have also sold one to africa for a pine apple farm, because the pines didnt root deep enough on the hard dry african soil.
Thanks Renze. I didnt think anything like that was used in this neck of the woods, at least that deep. I just figured it was for compaction or contamination but I guess there is a little bit of science to it as your crazy soils. You must have very few or no rocks to deal with.
I thought my soil was messed up. Within 100 feet I can go from nothing but rock to clay to sand to a nice loamy soil.
Thanks again for the long explanation.
/ Very Deep Plowing...Why? #7
Go do a search on deep tillage. There is more than one equipment manufacturer around and the reasons for it vary from soil type to soil type.:D :D :D
Most are not three point type equipment!:D
/ Very Deep Plowing...Why? #8
Renze - wow, thanks for the in-depth explanation. It's easy to forget how agricultural needs can vary so much in different parts of the globe.
/ Very Deep Plowing...Why? #9
Most deep tillage, lets say 90% of what i find on Google searching "deep tillage" are subsoilers that dont change the actual soil profile, just shatter the deeper layers.
Farm soil is very expensive in Holland, generally above 35.000 Euro per hectare ( thats maybe 8.000 euro per acre?) for reasonably good farm soil. thats why we tend to invest more in soil structure and profile alterations than most American plains farmers would...
Off course, the absence of rocks, and the usually high ground water table are also factors that make deep ploughing occur more in Holland than anywhere else.
/ Very Deep Plowing...Why? #11
Renze
Well done with the explanation!!! I understand they are doing this type of deep plowing in Italy as well now due to chemicals being in the ground from years of farming? Is this correct?
/ Very Deep Plowing...Why? #12
the hard pan was created through years and years of chisel plowing and molboard plowing we use V-rippers to incorporate this years fertilizer(manure usually) and to break up the hard pan to help the roots grow down deeper for moisture
/ Very Deep Plowing...Why? #13
Egon said:
Hmm... Never heard or seen that deep ploughing also occurred in Canada...
I wouldnt really expect it there either, because in North America there is so much room that it would seem more likely to find a better spot for farming, a few miles away.
Thanks for pointing that out ! :)
/ Very Deep Plowing...Why? #14
Trac-Tech said:
Renze
I have seen many photos from Italy about deep ploughing with 3pt hitch converted bulldozers, as well as bigger farm tractors, and asked the Italians why they did it, but i could only get Italian answers that didnt learn me anything ! ;)
From what i've seen, the Italians dont go any deeper than 2 feet, yet i still dont know why..?
YouTube - Aratura Budrione 2008
looking at this video of a classic 1950's Landini tractor ploughing deep, i dont know if its related to chemicals, did there ever were chemicals in the 1950's ??
/ Very Deep Plowing...Why? #15
It depends what you call deep.....?In england where we used to grow potatoes 15 inches was normal every year but different soils play a big part...we used a 6 bottom rollover on a 115hp fwa..????????
/ Very Deep Plowing...Why? #16
My family in Ontario, Canada had a White 5-18" plough, with which they could plough 6 inch... they said that was the average ploughing depth there. (they hadnt used it in 10 years, but now pulled it from under the brush, to plough a 40 year old pasture which they hired from a neighbor that stopped farming, to grow wheat)
In Holland, most farmers on sand, plough 10 inch, most clay farmers plough 12 or 13 inch.
With potatoes on hills, you need a bit more loose soil to build your hills from ;)
/ Very Deep Plowing...Why? #17
We began deep plowing at Dole in 1992 as part of our commitment to sustainable agriculture and better nutrition. Unlike conventional plowing, deep plowing rejuvenates the soil.
While most plows merely turn the topsoil six inches, deep plowing reaches down three feet deep, exposing new, nutrient-rich soil.
/ Very Deep Plowing...Why? #18
One could only wish!:D
/ Very Deep Plowing...Why? #19
there are nutrients in the lower soil levels.. so they're farming fertalizer and improving drainage on the fields....
/ Very Deep Plowing...Why? #20
That totally depends on the area: in my area, it would only bring up yellow beach sand that will be blown away in a dry summer... Over here, deep ploughing is only done to dig the topsoil back from under landfill, and on heavy soils like peat or clay.
2022 Peterbilt 567 T/A Wet Kit Day Cab Truck Tractor (A61568)
2022 Peterbilt 567...
2021 Takeuchi TL10V2-2 Track Loader with 76in Tooth Bucket (A63118)
2021 Takeuchi...
2018 Chevy Traverse 3rd Row Seating (A63118)
2018 Chevy...
2016 Lincoln MKT AWD SUV (A61569)
2016 Lincoln MKT...
TEST YOUR BID BUTTON! (A62129)
TEST YOUR BID...
2025 Auger Bits Skid Steer Attachment (A61567)
2025 Auger Bits...
