Snow 3pt snow blower
/ 3pt snow blower #1
pathman
Member
Val Belair Quebec
MF GC2310TLB
Hey guys, I was wondering if any of you have any photos of how you hooked up your hydaulics for your rear 3pt snowblower. I am looking and getting a 2 spool valve. 1 for chute rotation and 1 for chute direction. When the BH is off we have 3 hoses. one of which we need to connect together so that the 3 pt works, which leaves 1 hose. what's the set up I'm looking for?
/ 3pt snow blower #2
you need an open center two spool valve, the open center part means that when not in use fluid flows from on hose to the other (of the tow you connect together) when in use excess fluid goes into the third hose and to the hyd tank.
the two spools are for the two hyd circuits (to run the rotation and angle)
Surplus Center is recommended often on this board as a good place to get hyd parts.
Aaron Z
1998 Volvo VNL64T Sleeper Truck (A62679)
1998 Volvo VNL64T...
New/Unused ATS Plasma Cutter (A65583)
New/Unused ATS...
Ellis Band Metal Saw (A62679)
Ellis Band Metal...
2023 KUBOTA SVL97-2 SKID STEER (A65053)
2023 KUBOTA...
2019 HINO 268 4X2 S/A NON CDL BOX TRUCK (A59914)
2019 HINO 268 4X2...
Water Tank (A62613)
Water Tank (A62613)
