Deere 5210 cab questions
/ Deere 5210 cab questions #3
Looking at 5210 with cab for sale.
Any 5X10 series owners out there? How is the cab?
Would the cab come with a radio & speakers, or is this an option? Or is it just pre-wired?
the only thing i can tell you is JD improved the cab greatly between the 5010 series to the 5020-5025 series. i have heard the 5010 arent as quiet as the newer cabs. as for the radio, i honestly have never seen a JD in that size that already had a radio factory installed in it. i know some of the row crop tractors came with tape decks/ radios, but the other day i sat in a 5525 and didnt see a radio in it. from what i know, the dealer can install one for you if you want, so maybe they are pre-wired already.
Cab shows 79db noise level inside during the "nebraska" tests. I'll check other tractor cab noise levels.
I hear the "10" series cabs were made by Laurin, not JD. They look a little small and tight inside. The floor also is not a flat platform. I found out this one has AC & am/fm and a shuttle shift, no reverser.
1994 STRICK DURAPLATE VAN TRAILER (A63290)
1994 STRICK...
24in pin on tooth excavator bucket (A61307)
24in pin on tooth...
BUSH HOG 5' ROTARY CUTTER (A63745)
BUSH HOG 5' ROTARY...
CONEX BOX (A63569)
CONEX BOX (A63569)
6ft Tiller (A64047)
6ft Tiller (A64047)
ALLMAND MP65-8E1 PORTABLE (3) PHASE GENERATOR (A63276)
ALLMAND MP65-8E1...
