Pressure Washer Dangers
/ Pressure Washer Dangers #1
johnnydel29
East of Albany, NY
JD 2305
I was using my gas pressure washer the other day to clean our concrete patio and decided it would be a good idea to grab one of the plastic lawn chairs w/ one hand and spray it down with other. Well, the pressure washer gun bounced off the chair, swipped my forearm. Of course my wife yelled at me, and my friends, made fun of me. The wound looked alot worse when it immediately happened. Luckily, it did not hit me in the eye.
So, what I learned is when power washing: wear eye protection and hold on w/ both hands!!
/ Pressure Washer Dangers #2
I had the same thing happen while at the hunting cabin.
I made a meal in a glass Corning dish and it burned fast.
I thought I would use the pressure washer. I was holding the dish in one hand and the wand in the other. Did the same stunt.
I did not tell my wife of either thing, hurting myself or washing the dish. The dish was clean and she never knew the difference! It saved me some elbow grease of scrubbing the dish!
/ Pressure Washer Dangers #3
Thanks for posting the information and photo. That's a good warning.
/ Pressure Washer Dangers #4
*So, what I learned is when power washing: wear eye protection and hold on w/ both hands!!
*I learned the same dumb thing at the car wash the other day while cleaning out a 55 gallon drum holding the drum in my right hand and the wand in my left hand flipped over & got my right hand near the base of my thumb.
The water jet instantly cut about an inch long place in my hand as the tip of the nozzle was only about an inch away from my hand.
I can see why Tractor hyd Hoses can be dangerous,
/ Pressure Washer Dangers #5
Due to the possibility of fluid being injected into the skin, such injuries should probably be seen by a doctor, as they are different from ordinary cuts due to the fluid injection possibility, if I remember correctly. At least I've heard that from a few people plus the cautionary label on the pressure washer I have.
/ Pressure Washer Dangers #7
I thought I was the only one!:eek::D
I was using an electric pressure washer of about 1600psi.......honestly, I didn't have any respect for it...
I was washing off my ATV and I reached down to rub off some mud with my hand and the pressure washer just grazed across my wrist......did the same thing as your arm- removed the top couple layers of skin. I was concerned because I've always "heard" that water in the blood stream could be fatal.
I'll tell you, it really did burn worse than what the injury looked like it should....it seeped for a few days and then finally scabbed over. That's been about 2 months ago and I still have a slight scare from it.
Now, I have MUCH more respect for even the smallest of pressure washers, and I'm now using a gas one....
/ Pressure Washer Dangers #9
But there are times - for instance suppose you have to climb a ladder to spray. My personal rule is one hand for the ladder and the other for whatever tool.
I've found that it's only the initial pull-the-trigger that has the kick. So I hold both the ladder and wand with one hand and pull the trigger with the other. Then once it's spraying I try to use a single hand to hold the wand. A bit dangerous, but so is falling off the ladder.
/ Pressure Washer Dangers #10
Great idea to issue this warning. With maximum pressure (small nozzle opening at close range), you could lose a piece of you. They are definitely not toys.
/ Pressure Washer Dangers #11
Water in the blood stream fatal? I thought the major component of blood was water.
I have been careful and lucky with my engine driven pressure washer. Used if for hours yesterday (barefoot) and was very conscious about controlling the direction of the "muzzle." A pressure washer can really give you a bad wound and is not to be used casually. You need to keep your mind on-task.
When I was in the service we used to get shots (immunizations and the like) from a high pressure gun instead of a needle. It was not like the painless "hypospray" as seen on "Star Trek." We were always cautioned to be sure to NOT MOVE or FLINCH when getting the shot as the tiny high pressure stream would slice you like a scalpel.
The good news, if there is any, regarding wounding yourself with a pressure washer is that tap water is not nearly so nasty as hydraulic fluid when injected into your flesh. The tissue damage from a pressure washer "incident" can be extreme and can happen so fast your reflexes can't save you.
Lets all be careful with these things.
Pat
/ Pressure Washer Dangers #13
You can most definitely die fr bubbles in your bloodstream. It's why SCUBA divers have to decompress after deep/long dives. Over here it's currently called "the bends". 100 years ago it was called "caisson disease" because of the workers digging the foundations for (I think) the Brooklyn Bridge. They would come up fr the pressurized caissons and the air would bubble out of their blood like CO2 out of Coke. Bending over seemed to help w the pain of a bubble lodged around the spinal column. Perhaps one of the doctors on here might care to elaborate.
Dunno what it's called in Holland/Europe.
/ Pressure Washer Dangers #15
Air embolisms are not fun but are also NOT water injection.
Dirty clothes going in with the water would not be a good thing but the origin of the comments was regarding how water is the major portioin of blood and adding water is not typically fatal. (like air may be.)
Down in the caisson celebrating a milestone of progress the champagne is opened and consumed by the celebrants but... it is pretty flat and NOT bubbly. Then when depressurizing to return to the surface all the celebrants start belching like it is going out of style.
A dive that normally requires no decompression, not even a "safety stop" can give you the bends if you fly too soon afterward as cabins are not pressurized to surface pressures.
Pat
/ Pressure Washer Dangers #16
I do a demonstration of how powerful water streams are under pressure. My 4000psi Hot water steam cleaner has a quickchange nozzle. I have one for reaching eaves and for cutting greas and clay from undercarriages. Its a focused stream and I can stand 4 feet away from a large watermelon and slice it cleanly down the middle. Ive cut bricks and even uesd it to cut the chip and sealed road in front of my shop. I also cut a new fan belt off my dump truck with it when i forgot the tip I was using.
/ Pressure Washer Dangers #17
a buddy of mine that uses sewer jetters would always talk about cutting 2x4's in half........this was years ago and i know the new ones will do more...........well, they use them to cut steel with in a cnc type machine....
/ Pressure Washer Dangers #18
You're pretty much correct Sandman.
Water in the bloodstream = not fatal, not harmful, if it's done in the correct manner. ie; IV (the IV fluid of choice today is normal saline, but I can remember when it was either 9%NS or D5W (9% saline in water or 5% dextrose in water)). Contamination would be the key issue.
The problem with water injection is the trauma to the tissue, not to big an issue with lower pressure rigs (3000#) but in the high or ultrahigh pressure (H= 10-20K, UH= 40K) those injuries can be devestating. high pressure water can saturate the sub-cutaneous and muscle tissues (gets into the cellular and interstitial areas)
However, don't misunderstand me. A 2500# rig can still do a number on you.
/ Pressure Washer Dangers #19
The machines that cut steel w water are called waterjet cutters. They run in excess of 60,000 PSI and inject an abrasive into the water stream just prior to the stream exiting the nozzle.
Oh ya, and they'll take your fingers off in the blink of an eye!
/ Pressure Washer Dangers #20
Years back I was hosing off a skidder with a #3800 pressure washer. As I was cleaning off the rear and holding onto the the rear chokers and chains, I attempted to whip them out of the way to clean behind them. The force of them coming back brought my hand in front of the wand and it proceeded to blow my finger nail right off. I mean the stream just grazed the front of my finger high enough on the finger to grab the 32nd of an inch exposed fingernail beyond the tip of the finger and 'Whoof" it was gone. I was surprised. I agree with the gentleman in regarding that wand as if it is a loaded gun. Also, it is probably a good idea to always use two hands on the wand at all times.
