rachet tie downs-tractor hauling
   / rachet tie downs-tractor hauling #1
rollbar
2005 4520 jd
I was wondering if any of you guys use rachet tie downs to haul your tractors on trailers.
I have a 4520 jd w/400 cx loader, a 16' 7000# trailer w / double brakes. I use two
10,000 lb 2 1/2" rachet tie downs instead of chains and boomers. I loop the webbing around the front axle and hook to front of trailer. am i safe? thanks for any comments
   / rachet tie downs-tractor hauling #2
I use 4 ratchet straps on my 2305, but I don't know if I'd trust them on a 4x20 series, that's a lot more weight to hold down.
   / rachet tie downs-tractor hauling #3
They are used to haul a lot of heavy loads. I would want to make sure they will not tear.
Also, I prefer the ones with the chain ends (they seem to not come undone).
D.
   / rachet tie downs-tractor hauling #4
I use them all the time, but they are very large ones. I use 4 with axle straps on each corner. I use them to haul my Jeep also and its nice not to have a bunch of chain around. I would not haul your tractor, or mine, around with only 2, no matter the size. There is more that can break on these compared to chain binders, and if you have a rachet going bad, they can slip.
   / rachet tie downs-tractor hauling #5
****Read Dargos thread /post about straps. *****
   / rachet tie downs-tractor hauling #6
   / rachet tie downs-tractor hauling #8
:rolleyes: Mine are more than 2" and are rated for much more than that. I have 4" and they are made to do what I am using them for. Anything ratted for 10K should not be allowed on the road when using them for a 3-5K tractor. The forces that could ack on the tractor in hard breaking, bumps, or a crash would be 10 times that. Long story short, just like with chains, use the right stuff, and don't take an example from someone who used the wrong stuff to say that straps should never be used.:D
   / rachet tie downs-tractor hauling #10
I don't know what state you are from but you might want to check with your D.O.T. because in some states they are not legal.
(3) ROLLS OF 4' GALVANIZED FIELD FENCE (A54757)
(3) ROLLS OF 4'...
Year: 2021 Make: Dodge Model: Durango Vehicle Type: Multipurpose Vehicle (MPV) Mileage: 44928 Pla... (A55758)
Year: 2021 Make...
BrushFox HD-78STD 78in Rotary Brush Cutter Skid Steer Attachment (A53421)
BrushFox HD-78STD...
UNUSED Bubble Aluminum Foil Reflective Insulation (A53117)
UNUSED Bubble...
20357 (A55758)
20357 (A55758)
2004 INTERNATIONAL 4300 SBA 4X2 (A51406)
2004 INTERNATIONAL...
