Oil & Fuel Oil drain plug size on 07 TL100A??
   / Oil drain plug size on 07 TL100A?? #1
lars
Member
Just got over a hundred hours on the tractor and bought all the filters and oil. I glanced at the drain plug and it's an allen head bigger than a 3/8ths inch. I'm not near the owners manual or the tractor which is 100 miles north at the in-laws, so what size is the allen needed for the drain plug?? I plan to get a 3/8 drive set and want to make sure whether it should be metric or english.
Thanks - Dan
   / Oil drain plug size on 07 TL100A?? #2
Thanks - Dan
It is metric, I can't remember the size but someone else will jump in and say what it is.
I bought a 3pc set from Autozone and I think it was the smallest socket in the set.
Thanks Robert - I called the service department at my dealer and it is a 12mm. They sell an allen wrench, but I think I'll get the 3/8" drive to fit on a wratchet. - Dan
   / Oil drain plug size on 07 TL100A?? #4
You might want to get it in 1/2" drive. They have some real gorillas at the engine factory-those plugs are overtight the first time off. The front hubs probably use the same plug.
That's probably good advice Rick, but as I have a bunch of 3/8 wratchets laying around, and all my half inchers are part of a set, I thought I'd just leave one with the attachment in the tool box on the tractor. I'll give the 3/8 a try and upgrade if needed.
Thanks - Dan
Black Steel Diamond Plate (A55758)
Black Steel...
light tower (A56857)
Bell 1600 Gallon Nurse Trailer (A56435)
Bell 1600 Gallon...
2018 JLG 600S TELESCOPIC BOOM LIFT (A52709)
2018 JLG 600S...
2015 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A58017)
2015 FREIGHTLINER...
2007 Heil Heavy Duty Aluminum Tank Trailer (A56435)
2007 Heil Heavy...
