4520 Cab - Figuring it out
/ 4520 Cab - Figuring it out
Hey Darin,
Nice work on the upgrade. Why the 4520 instead of another 4720 with a cab?? Is the extra couple HP not a big deal?? Did you get 3rd SCV, a diverter kit, or power beyond??
I finally started moving rounds off my GN last week with my 4720/400x/spear/Ballast box with gravel and fluid in tires. I figure they were about 1200lbs and I had no problem at all. I even did a little test to see if I could pick up and place bales off the second row of the GN, and I could. Had to be VERY careful, but it did it.
Wanted to say thanks to everyone that's offered advise over the past few months.
-Jer.
I think I could live with a 4320 to be honest for what I am doing. It was $1K to go from 4320 to 4520. 4520 to 4720 was $3500. I didn't think it was required.
yes on 3rd valve.
No on the divert and power beyond - I would never use them.
Good deal on the hay bales. THe 2nd row can be a tad scary at first but it does a good just. Just don't turn and back and the same time. Pick the bale up, back up, lower the bale then turn - it will be all good.
D.
Parts are starting to arrive at the dealer. The tractor should be in from GA next week sometime. I doubt it will be ready next week, but maybe the week after.
D.
/ 4520 Cab - Figuring it out #44
Nuru,
I have an open station 4720, she's loud. My earplugs are a permanent fixture in the fender storage box!!
-J.
/ 4520 Cab - Figuring it out #45
yes on 3rd valve.
D.
Thanks Darin. I didn't even consider anything but a 4720 and was just wondering if I could've got away with less. I was lucky enough to find mine used and close to home, so I jumped at it.
-J.
-J.
If you got a deal, don't worry about it.
After having had a 4720, I never used all the power. Not sure I could get it all to the ground unless it was a bit heavier. Saved $3K or so buying a 4520. I might have it this week, if not next week.
D.
/ 4520 Cab - Figuring it out #47
Nuru,
-J.
Oh OK, thanks for responding.
/ 4520 Cab - Figuring it out #48
D.
Post pics when you get it.
2009 Ford Ranger Pickup Truck (A66736)
2009 Ford Ranger...
2008 EPI FRAC MANIFOLD TRAILER (A67714)
2008 EPI FRAC...
2014 Ford Escape SUV (A66738)
2014 Ford Escape...
2000 CATERPILLAR 322BL EXCAVATOR (A65056)
2000 CATERPILLAR...
3145 (A63117)
3145 (A63117)
219065 (A65056)
219065 (A65056)
