4520 Cab - Figuring it out
/ 4520 Cab - Figuring it out
Hey Darin,
Nice work on the upgrade. Why the 4520 instead of another 4720 with a cab?? Is the extra couple HP not a big deal?? Did you get 3rd SCV, a diverter kit, or power beyond??
I finally started moving rounds off my GN last week with my 4720/400x/spear/Ballast box with gravel and fluid in tires. I figure they were about 1200lbs and I had no problem at all. I even did a little test to see if I could pick up and place bales off the second row of the GN, and I could. Had to be VERY careful, but it did it.
Wanted to say thanks to everyone that's offered advise over the past few months.
-Jer.
I think I could live with a 4320 to be honest for what I am doing. It was $1K to go from 4320 to 4520. 4520 to 4720 was $3500. I didn't think it was required.
yes on 3rd valve.
No on the divert and power beyond - I would never use them.
Good deal on the hay bales. THe 2nd row can be a tad scary at first but it does a good just. Just don't turn and back and the same time. Pick the bale up, back up, lower the bale then turn - it will be all good.
D.
Parts are starting to arrive at the dealer. The tractor should be in from GA next week sometime. I doubt it will be ready next week, but maybe the week after.
D.
/ 4520 Cab - Figuring it out #44
Nuru,
I have an open station 4720, she's loud. My earplugs are a permanent fixture in the fender storage box!!
-J.
/ 4520 Cab - Figuring it out #45
yes on 3rd valve.
D.
Thanks Darin. I didn't even consider anything but a 4720 and was just wondering if I could've got away with less. I was lucky enough to find mine used and close to home, so I jumped at it.
-J.
-J.
If you got a deal, don't worry about it.
After having had a 4720, I never used all the power. Not sure I could get it all to the ground unless it was a bit heavier. Saved $3K or so buying a 4520. I might have it this week, if not next week.
D.
/ 4520 Cab - Figuring it out #47
Nuru,
-J.
Oh OK, thanks for responding.
/ 4520 Cab - Figuring it out #48
D.
Post pics when you get it.
