blowing fuses
/ blowing fuses #1
robert421960
Rockholds Ky
2014 Kubota L3301
good afternoon people
i left my key on my farmpro 2425 the other day accidently
so i went to jump start it this afternoon
after cranking for just a second or so it quit cranking
the top fuse was blown and so was rthe second one
i replaced those and gagues worked and all
but tractor will not charge battery
but amp meter does show output from alt
the fuses blew again
any ideas?
i have jumped it before when i have been to stupid to turn off key
but never had trouble
Thanks
Robert
/ blowing fuses #2
Loose/dirty electrical connections are common, I'd check those before getting any more complicated. Then compare voltage across the battery posts; first with the engine off, then with the engine running. Sometimes you have to give it as much as half throttle before charging voltage is excited outa the alternator.
//greg//
/ blowing fuses #3
Greg right about getting the rpm's up to charge the battery. Here's what I would do
1) have you changed out the chinese fuses to American made?
2)cleaning electrical connections; Battery negative cable to tractor frame- remove all paint and use a star washer
3) blowing fuses check your starter/clutch safety switch
4)try charging the battery using a battery charger
5)clean and sand alternator conections and use star washers some are painted/or loose Good luck
/ blowing fuses
after posting this i saw another recent post on the same line and yes it was my switch
all the wires leading to the switch are bare so ill have to fix those also
thanks for everyones help
Robert
832635 (A61166)
832635 (A61166)
2015 Komatsu PC210LC-10 Hydraulic Excavator (A60352)
2015 Komatsu...
2018 Freightliner M2 106 AWD Altec AA55 56ft. Insulated Material Handling Bucket Truck (A60460)
2018 Freightliner...
2019 Ford F-550 4x4 Dur-A-Lift DTAXS39 39ft. Bucket Truck (A60352)
2019 Ford F-550...
2008 TEXAS BRAGG GOOSENECK FLATBED (A58214)
2008 TEXAS BRAGG...
Hyster H155 XL Forklift (A59213)
Hyster H155 XL...
