New Guy with a BX24 question.
/ New Guy with a BX24 question. #21
LBrown, he said he's got an F350 Superduty.
I reckon he's got the truck department covered ;)...
Truthfully though, since you're tow vehicle is probably already set up for trailer brakes, I'd opt for them, regardless of what kind of trailer you get. You're probably only talking 100-150 bucks or so over one without...
/ New Guy with a BX24 question. #22
...as the F350 has MORE than adequate braking for a 3-4000lb trailer.
Having towed my tractor on a trailer with brakes and without, the brakes have every bit as much to do with keeping the trailer BEHIND the truck as actually stopping the rig.
I've been in an emergency maneuver before and without trailer brakes, I would have been in a jack-knifed mess, guaranteed. With trailer brakes, everything was great. I wouldn't wish an experience like that on anyone.
I'll tell you, I was glad I had my tractor lashed down really well, though.
/ New Guy with a BX24 question. #23
Well, it is a Ford :eek:
I just had to say that, I like my Duramax.:D
Seriously though, if you are runnng a light trcuk, like a ranger, colorado or s-10, you want trailer brakes, especially on long hauls and down steep hills. Most people think that the braking system in their trucks is barely adequate for the vehicle it's self. Let alone if you add another 3 or 4000 lbs behind it. That is a lot more energy pushing you. Also, with a 4000 or 5000 lb truck, that much weight could in the right conditions over power your truck without brakes on the trailer.
I towed a Geo Tracker with my S-10 once. Just getting off on a flat ramp from speed limit was a bit nerve racking, and my truck had disc brakes all the way around it.
Another thing to note is the tongue weight. With a short trailer there is more weight added to the tongue. With a slightly longer trailer, you can offset that weight a bit which will help the truck manuver better.
Also, read the specs on your hitch and ball, the ones you buy at Wal-Mart are typically only rated for 5000 lbs (the hitch). With a 3000 tractor and your trailer, you could easily be at max. Although the hitch may hold up, they are not as strong and will weaken after time. I have seen the pin holes widen and cause a lot of play which results in some good banging back and forth. Not fun when in a turn going down hill especially in a small truck.
Brake options do not add that much cost to a trailer, and in the end lessens the wear and tear on the tow vehicle when properly adjusted.
We all have seen that overloaded trailer with the lttle 12 inch tires swinging back and forth on the road at 80 MPH, it just a matter of time that it will crash. I don't about everyone, but $16,000 tractor is worth spending the money on a descent trailer that will not fail as easily. Also, there had been many times when I wished I had a larger trailer to make a few extra bucks hauling someone's car.
One last thing. It also seems to be easier to back a heavily laiden longer trailer than a small strailer at it's max.
/ New Guy with a BX24 question. #24
I recently backed out of purchasing a used tandem axle for the tractor as the condition was just too questionable leaving me with no choice but to tow the BX24 with my single axle 6x12 for this required move. I did a once over on the trailer and decided to give it a try for a 25 mile run from NJ to NY over the GW bridge. I waited until 11pm for reduced traffic levels as I planned on going no faster than 50mph. I was quite surprised to see how well the trailer held the load. It's a 3k GVRW and it barely seemed to squat from the BX. I balanced the load to not weigh down on the tounge. I had to put the FEL over the front bars of the trailer. I had the weight of the tractor rear tires over a support cross beam under the trailer flooring. Strapped it down and went on my way. The trailer handled it very well. As stated, I did no more that 50mph and kept plenty of space btwn me and the car in front of me. I will continue to look for a tandem but will say that for limited use the single axle can handle the task well.
2018 International DuraStar 4300 Vactor RamJet Sewer Jetter Vacuum Truck (A64556)
2018 International...
2004 Club Car Carryall 6 Medical Utility Cart (A64553)
2004 Club Car...
2019 Ford F-450 Flatbed Truck (A64194)
2019 Ford F-450...
2013 BMW 528i Sedan (A64557)
2013 BMW 528i...
2021 Chevrolet Silverado 2500 HD 4x4 Crew Cab Pickup Truck (A64556)
2021 Chevrolet...
2016 VOLVO VNL 6X4 T/A SLEEPER TRUCK TRACTOR (A67148)
2016 VOLVO VNL 6X4...
