JD870 Will Not Start
/ JD870 Will Not Start #1
NWL
Member
I last used my JD 870 about 6 weeks ago and all was fine. I got on it the other day, turned the key, and nothing. The dashboard lights come on, headlights work, but it will not even try to turn over. I get nothing when trying to start. Charged the battery, gear shift in neutral, PTO disengaged, and there is power to the starter. Today I plan on taking the battery out and giving it a good cleaning and check the fluid level. I have read the other posts concerning starting problems and learned about the solenoid, but I have no idea what it looks like or where it is as my owner's manual does not show it's location.
Any information you folks can provide will be greatly appreciated!!!
Update: Cleaning the battery and connectors did not solve the problem. :( Please folks, I need your input! 20 some people have looked at my post, but none have left replies.:confused: I'm open to any and all suggestions! Thanks:)
/ JD870 Will Not Start #3
If your starter looks like the one in the picture, the large wire should be hot at all times and the small wire should only have power when the key is in the start position. If you have power at these locations then the problem is probably the starter (assuming there are good connections at the starter). If you don't have power at either of these connections you will have to trace back the circuits to find the problem. You can jumper power from the large wire to the small wire terminal of the starter to see if the problem is coming from the ignition switch (Warning: This will engage the starter). Also, you can work the starter mounting bolts in and out to make sure you have a good ground.
/ JD870 Will Not Start #4
NWL,
How did you ascertain this? You measured voltage where? (And note that the presence of 12V doesn't imply that there is any power available; it just means it might be available.)
truckie36's post does apply to your 870, and the picture is close. The "always hot" wire will be a heavy gauge black wire, and the "hot when cranking" will be a lighter gauge wire which is white.
As truckie36 says, check for voltage on both wires when the key is in the spring-loaded crank position. And as truckie36 says, "If you have power at these locations then the problem is probably the starter (assuming there are good connections at the starter). ".
If you don't have about 12V on the white wire, then there could be a problem with a "neutral start" relay which must be closed in order to for voltage to be present at the white wire.
The "neutral start" relay is closed/energized only under "safe conditions" which involve several components. The key must be on (could the key switch be bad?) The seat safety switch must be closed, either because there's weight on the seat, or it's been defeated by tilting the seat forward and pulling up on the switch.
In addition, the seat switch must be closed for some length of time (pretty short, maybe 1 or 2 seconds, so if you hit a bump and bounce up off the seat, the tractor doesn't shut down). There's a "time delay control module" that provides for this delay.
The PTO safety switch and transmission-in-neutral switches are also involved. For a hydrostatic transmission (was it available for this machine?), the park-brake switch would also be involved.
Here's a series of tests:
0) Double check that you have PTO off, transmission in neutral, and for good measure, the parking brake set (that's normally only for hydrostatic transmission machines).
1) Then, with weight on the seat, and key in spring-loaded "crank" position: There should be 12V on the white wire at the starter. If so, some part of the starter or starter solenoid is bad (they're one unit).
2) If no voltage under those conditions, .............let me know and I'll post further instructions.
Thank you truckie36 and TedLaRue for your suggestions! :D My father only checked "the always hot wire", so now we know that there is another one to check. :eek: We'll try again today and I'll post the results later.
Thank you both for taking the time to help me!!!:)
Thunderstorms moved in and kept us from trying your solutions (sadly, I do not have cover for my 870 at this time. It's on my "to do" list.:D ) I will post as soon as we get a chance. It may not be for a day or two. Thanks again for your help!
/ JD870 Will Not Start #7
Disengage the PTO and sit on the seat.
zzvyb6: Pto is disengaged, it's not in gear, and I was sitting on the seat. Any other ideas?
/ JD870 Will Not Start #9
(This is not a standard OEM recommendation..) But, you can use a screwdriver to short across the terminals (the big red wire and the little white wire) on the selenoid to "jump" the starter. You'll get a big spark and it will likely burn a spot on the screwdriver; but the starter should engage and the engine should start (if the key is on).
If the selenoid is bad, the starter won't engage and you'll hear a good click and whirr; but no go on the engine. If the starter is bad you should hear a good click and a clunk; but no go on the starter and engine.
Sometimes the starter bendix will engage onto the flywheel and just hang there -- and the next time you want to start the engine it's a "no go". When that happens; the next time you turn the key, all your instrumment lights will dim and the selenoid clunks and nothing else happens -- starter doesn't spin, etc.
Best of luck and please let us know how things turn out.
AKfish
Update: Tried TedLaRue's suggestion of checking the hot when cranking wire, and thanks to truckie 36's picture, I could find it.:) Assuming we did it right, we did not get any indication of voltage at that wire. Any ideas as to what we should check next?
Thanks again to everyone who has posted their thoughts on this problem :D
/ JD870 Will Not Start #11
NWL,
In the nutshell, here's how your starting system for you John Deere 870 works. The safety switches (PTO switch, seat switch, and transmission-in-neutral switch and (if you have one) mid-mount PTO switch) all feed into the Time Delay Control Module (TDCM) which is the large black plastic box which is on the right side of the attached picture. There is a black w/red stripe wire connecting the TDCM to the Neutral Start Relay which has the red arrow pointing to it in the picture.
Check for voltage on that black w/red stripe wire when the switch is in the cranking position. If you have voltage on that wire when you're trying to crank the engine, but no voltage on the white wire from the Neutral Start Relay to the starter, then that relay is bad. You might try rapping it with a screwdriver handle while you're trying to crank the engine in case it's just stuck.
If that red/black wire doesn't have voltage on it when you're trying to crank the engine, then you need to check the TDCM. Let me know if you want some guidance checking that.
/ JD870 Will Not Start #12
NWL,
Here's something else that's really easy to check. Make sure the black plug that plugs into the white receptacle on the bottom side of the Neutral Start Relay (the one with the red arrow in the picture in my previous post) is plugged in tight. I was messing with mine when I took that picture, and had partly pulled that plug out. When I got on my tractor to start it, I had exactly the same symptoms you described. Wouldn't that be a nice resolution to your problem!
Update: I got to a point that was beyond my basic knowledge, and because of the amount of time it would take to get up to speed, I bailed and got hold of a mechanic to come and look at the tractor ( not an easy feat in our little neck of the woods!). He went through the same procedures outlined above by TedLaRue, and ended up at the seat switch. Power was going to the switch, but it was not receiving it (fuse was good). The thought is the seat switch went bad, which is what the JD service tech believed was the last thing to check before he ran out of ideas. So I'll replace the switch, which will take a few days as the dealer is 70 miles away and I'll need it sent to me, but I will post an update on the result for future reference.
Thanks again to everyone who posted their ideas. :D
Latest Update: I really wanted an easy fix to my problem, but it was not to be. I replaced the seat switch but the tractor still will not turn over. :( I went back to TedLaRue's instructions for checking the Neutral Start Relay and I did it right this time. :) There is no voltage on the black w/red stripe wire when cranking the engine. I'm awaiting further instructions from him (bless his heart!) on how to check the Time Delay Control Module. I'll post the results soon.
Thanks to all who have posted. :D
/ JD870 Will Not Start #15
NWL,
Does your tractor have a mid-mount PTO? If not, look on the left side of the back of the tractor, close to the transmission/hydraulic oil dipstick. You should be able to see two wires going to the rear PTO safety switch mounted on the side of the transmission case. Close by you should see a couple of single-wire connectors with a short piece of wire between them. That wire is a substitute for the mid-PTO switch. If something caught on that wire and pulled it loose, your tractor wouldn't start.
For the TCDM (time control delay module), there's a short wad of wires coming out the bottom, and then a connector. You can test voltages at that connector.
With the key in the crank position, you should have 12V on the Blue/Yellow wire and the Blue/Red wire.
If no voltage on the Blue/Yellow wire, try again with the seat switch in the "defeat" position (i.e., tilt the seat forward and pull up on the switch). This removes the PTO switch(es) from the mix, leaving only the transmission-in-neutral switch.
Depending on your results, you'd need to check out the transmission-in-neutral switch or the PTO safety switch. There are several combinations of those switches and the seat switch here, and there is also the "old version" and the "new version" of the wiring which involves those switches, so I'll stop providing speculative choices until you post back.
SUCCESS!!!!!! It finally starts. :D In a nutshell, here's what happened since my last post: Once we determined there was no voltage on the black w/red stripe wire on the Neutral Start Relay, TedLaRue sent instructions for testing the Time Delay Control Module as well as instructions for checking the "dummy" connector for the mid PTO (my 870 has no mid PTO). I disconnected, cleaned, and reconnected the "dummy" connector for the mid PTO while my husband disconnected, cleaned, and reconnected the connector for the TDCM. He went off to get the voltage meter, and I, just for yucks, decided to get on and see if it would start. Scared the you-know-what out of me when it started right up! :eek: So one or both of those connectors needed cleaning and/or one or both were loose and needed to be secured.
My thanks to all who posted there ideas. I learned a lot through this ordeal! :D See you on the forum!
/ JD870 Will Not Start #17
I am diagnosing this same problem. Great info.
Welcome to the forum! Yep, this is a great resource. I'm glad you found the thread and hope it is useful. TedLarue is great and is very knowledgeable and helpful. Send him a private message if you need further instructions.
Cheers!
/ JD870 Will Not Start #19
had same problem on 4300, all I had to do was wiggle the wires going to the nuetral switch and all was well. They really crammed that switch under the floor platform on the 4300 and the wires get pushed on by the platform.
/ JD870 Will Not Start #20
Hello, I am a new member here and am glad to have found this great source of info. Thanks to all those that take the time to help others!
I am having the same trouble getting my 870 to crank over, new battery and cables, I tested the TDCM wires as advised by TedLaRue above. I get 12V from the blue and yellow wire and only .75V from the blue and red wire coming from the TDCM when the key is held in the start position. Any advise on where to go from here is appreciated. Is the TDCM toast?
2017 Wacker Neuson ST31 Compact Track Loader Skid Steer (A61572)
2017 Wacker Neuson...
Tube Line Manure Spreader Nitro 275RS (A63688)
Tube Line Manure...
2021 BOBCAT T870 SKID STEER (A62129)
2021 BOBCAT T870...
2011 Jeep Grand Cherokee AWD SUV (A61574)
2011 Jeep Grand...
UNUSED WOLVERINE RSB66-66" ROCK SCREENING BUCKET (A64281)
UNUSED WOLVERINE...
2016 Peterbilt 579 Automatic High Top Sleeper (69") (A62613)
2016 Peterbilt 579...
