Those flat bars with the bend on the end(s) can also be pinned in place of where the upper link is pinned. That creates a fairly rigid (though fixed-height) drawbar attachment for a trailer or some such. I think you'd want two in that situation.
Not explained well. 1. remove upper 3ph link, 2. place bent ends of stabiliser bars over the pins of a drawbar, 3. place ends of drawbar into lower link eyes and pin with linch pins, 4. swing unpinned end of stabilisers up and together, and slide upper link pin through upper holes of stabilisers.
Drawbar is fairly rigid in every direction, though fixed in height.
I used these stabilisers horizontally on a Massey 135 since the check chains were so worn the drawbar swung wildly. I made some brackets to bolt under the axle where the fender u-bolts sit, in line with the lower-link pins on the diffy housing. The stabilisers are weak in compression but fine in tension, so you need to use both.
Jim
