Hydraulic Oil Change
/ Hydraulic Oil Change #1
Piperflyer
Gold Member
USA
Kubota3030HST
I'm in the process of changing the hydraulic/transmission oil on my Kubota.
Do I put back in the required 4 gals of oil that's called for or do I leave it down some? I have the front hydraulic bucket off the tractor, would this make a difference? Thanks
/ Hydraulic Oil Change #2
Fill till it is at the correct level. I don't know if you have a site glass or a dip stick. Either way, fill 3/4 of what is called for then measure and carefully and slowly with checks on the way, fill it up.
/ Hydraulic Oil Change #3
This is not a highly precise issue owing to the variability in the castings involved. Consider the area of the dipstick between the highest and lowest levels to be the "safe range". That way you will have adequate oil volume for heat dissipation and to supply the various functions that depend on that reservoir content.
/ Hydraulic Oil Change #4
Do this the first time and write down how many ounces it took and you can just dump than many in the next time and won't have to fool with that.
/ Hydraulic Oil Change #5
This is what I did when I changed oil in my 2003 bx1500 a while back .
Found out it took 76 ounces to fill it.
When I changed oil in the new bx1500 the other day i just dumped 76 ounces in it with no measuring and carefully and slowly with checks on the way filling it up.
TheBX23 and BX1500 trannys take 12 quarts even .
/ Hydraulic Oil Change #6
Fill to the recomended level..
soundguy
1274 (A62130)
1274 (A62130)
2003 McCormick XTX 185 XtraSpeed Tractor (A63118)
2003 McCormick XTX...
(1) 225/70R19.5 TIRE ONLY (A62130)
(1) 225/70R19.5...
Misc. Yard Tools (A62177)
Misc. Yard Tools...
LandHonor LHR-UBF12 12in Utility Blower Fan (A60352)
LandHonor...
Gehl RS5-19 (A62177)
