Adding Rear Remotes On A L3130
/ Adding Rear Remotes On A L3130 #1
Patternmkr
Hello All
I want to add on 2 sets of remotes on my L3130. I was at the dealer and was quoted about $1500 for just 1 set of remotes (parts only). This seems way outta line? Does anyone offer any aftermarket kits? I'd prefer the factory setup but the price is a problem.
I could probably do with just 1 set of remotes but figured if I was going to install one I might be sorry later if I didn't add the second.
I want to use the remotes for my hay rake and maybe my JD sickle bar. I have a Kubota 9540 and with fuel prices it seem wastefull to use the big tractor for smaller utility work. Plus it frees up the 9540 for just the haybine & baler.
I own a machine shop and can make just about anything I would need to install a universal kit.
Thanks
Scott
/ Adding Rear Remotes On A L3130 #2
/ Adding Rear Remotes On A L3130 #3
Based on the price when I bought my L3130 (2.5 years ago) w/3 remotes, the the install kit and first valve kit was about $600 list, the second valve kit was about $400. I got 3 for just over $1300 with tractor setup. I would hold the dealer's feet to the fire.
Vernon
Hey Vernon
Now that seem like a reasonable price. If I could get that price here I'd buy it in a minute. I'll call the dealer in Kentucky where I bought my 9540 and see what he can get it to me for.
Scott
/ Adding Rear Remotes On A L3130 #5
How similar is the L3130 to an L2800 or L3400? I just installed 4 remotes on my L3400 for about $475 using Prince stack valves and hoses/fittings from my local shop.
Tapped into the PBY on the FEL and mounted the valves on my ROPS. Real easy set up.
/ Adding Rear Remotes On A L3130 #7
I just priced a set for the L3940, it was $850 with labor but not pick and delivery of the tractor. That was for one set with Float option.
60in. Work Bench (A65640)
60in. Work Bench...
ALUMINUM TOOLBOX (A64277)
ALUMINUM TOOLBOX...
Towable Pipe Road Crossing Trailer (A63689)
Towable Pipe Road...
Anco 3Pt Ditcher (A66408)
Anco 3Pt Ditcher...
20ft Driveway Gates (A65579)
20ft Driveway...
Pallet of Four Pivot Wheels & Tires (A62177)
Pallet of Four...
