Got use 2763A Plow - Have ??'s
/ Got use 2763A Plow - Have ??'s #1
Jabroni
Central MA
Kubota BX24
I purchased the lightly used BX2763A plow today that was on the Hartford Craig's List for $1200. The ad was circulating around here earlier this week. The seller had no instructions, so I was hoping I could get a few questions answered.
1) The plow and sub-frame came off a BX23. I assumed that it would also fit a BX24 too? (if it doesn't, I'm in "vedy, vedy deep s...")
2) Does the silver Kubota brush guard have to be removed in order to mount the sub-frame?
3) There are 2 horizontal sleeves welded (by Kubota) to either side of the sub-frame. There must be a piece of hardware goes in the sleeve, that permit the sub-frame to hang from the front of the tractor's frame until the mounting rods can be passed thru the frame holes and securely lock it in place. As it is now, there are 2 long non-standard bolts with nuts and washers in those sleeves which allow the sub-frame to hang precariously from the front of the tractor's frame until the rods secure it. What missing pieces am I looking for?
On a side note, the plow blade fit perfectly in the back of my Tahoe, and we used the tractor's loader to place it in and to get it out. By using a 1500lb racheting nylon freight strap between the bucket and the far end of the blade, sort of cantilever fashion, we were able to lift it off of the ground and ease it gently in and out the Tahoe. Thanks for any help you can offer.
/ Got use 2763A Plow - Have ??'s #2
He had the blade & front hitch but not the literature? That stinks.
To my knowledge Kubota doesn't post their manuals on the web, so, you will need to seek a dealers help. If your local dealer has one in stock, you may be able to talk them into copying the manual(s) (hitch and plow).
Someone with this set up should be able to chime in to get you hooked up for the first time, but, I would still get those manuals.
Messick's has a page on their website and certainly could get them for you.
They are most helpful. Top notch outfit.
Kubota Manuals
Update:
I found the answer to #1. The subframe fits either the BX23 or the BX24
I took the brush guard off anyway.
Still don't know what hardware goes in those tubular sleeves welded to the vertical section of the subframe. Could use some help there if you can.
/ Got use 2763A Plow - Have ??'s #4
Those holes are for a wedge type retainer which takes the slop out of the frame to tractor mounting. The brush guard does have to come off.
The part numbers are as below 5 digits-4 digits the code is the six digits that follow. I don't know if they are even needed
qty P/N code
(2) 70001-0763 665136 t bolt
(2) 70001-0764 665137 wedge retainer
(2) 70001-0765 665167 nylon peg (inserts in t bole for locking
(2) 1/2" lockwashers standard split washers
Here is a pic.
Thank you, sir! Picture is worth a thousand words. That's exactly what I'm referring to. I'm headed to the dealer tomorrow, and your assistance will save us a lot of time searching for the P/N's.
/ Got use 2763A Plow - Have ??'s #6
I should have included these also
P/n 70060-02115 60" blade owners/parts manual
p/n 70060-02724 quick hitch owners and parts manual
Yes, those would be nice too. I guess I should prepare myself for sticker shock.
/ Got use 2763A Plow - Have ??'s #8
What is the nylon peg #70001-0765 665167. I am just unsure where that belongs.
Also if you don't mind me asking, JABRONI what did the this stuff cost you and did they have it in stock?
/ Got use 2763A Plow - Have ??'s #9
Also if you don't mind me asking, JABRONI what did the this stuff cost you and did they have it in stock? Also what do you use to hold the hoses along the tractor side?
/ Got use 2763A Plow - Have ??'s #10
1*This is the same blade That I have on this tractor.http://i283.photobucket.com/albums/kk286/lb59/100_2316.jpg
2*I don't have the brush guard on my BX1500 but it looks like I could put one on it with the blade on the tractor.
/ Got use 2763A Plow - Have ??'s #12
Did you ever get a front blade for your tractor?
/ Got use 2763A Plow - Have ??'s #13
I just picked one up a blade and hitch yesterday. The blade is new and the hitch is slightly used. The plow came with skid shoes too all for $1200.00. It seems I need to get a t-handle and the hose standoffs for the tractor??? I would also like to shorten the hoses to the correct length.
