Back Hoe bucket size
   / Back Hoe bucket size #1
fastpat
Travelers Rest, South Carolina
I just called my Kioti dealer and he says the smallest bucket for my back hoe is 12 inches wide. I need to dig some trenches and think a much narrower bucket might work better, say a 8-9 inch one. Any of you using a small bucket like that?
   / Back Hoe bucket size #2
I've got both a 9" and a 16" and had no problems with either.
The 9" makes a beautiful trench.
Call Rick Wallace.
Tom
   / Back Hoe bucket size #3
I'm glad I got a 9", I've dug some stuff up that a bulldozer operator pointed to and said he couldn't, it was a shale shelf on my driveway, I started poking at it and it was easy to separate it into big rocks and dig a ditch thru it. Around here in NW VA everything is rocks. I'll get a bigger bucket for more earth moving type stuff someday. Right now I wouldn't want anything bigger.
Mike
Thank you, gentlemen. Do you remember what brand or who made your 9 in. bucket? I have a Kioti 2385 backhoe, which works very well, so I need one that fits that model. I have quite a bit of trenching to dig to run drainage pipe to route water away from the house.
   / Back Hoe bucket size #5
Don't know if the number is the same, as I have a 2376 hoe, but the Kioti number is 293051 for the 9" "spoon". Works really well for trenching or small stump removal
   / Back Hoe bucket size #6
Hi, I have a CK20 with 9 inch, works great for smaller work, find a trench over 2 feet deep is dificult to get the bucket in without fiddling and harder to work in due to the wiidth also have the 16 inch, either one can dig a big hole in little time
The trenches I need to dig with a narrow bucket are about 8-10 inches deep. Most of them are to bury tubing to carry downspout water away from the house. I also want to run a water line from the house out to the back of the property to connect to a hydrant. Our ground doesn't freeze here, so burial of water lines is not deep. I don't know what code says, but I doubt it's more than 24 inches.
   / Back Hoe bucket size #9
I have a 12" bucket and a 24". The 12" is of course narrower but it is also much smaller volume which hurts. It takes a long time to trench with such small volume. My woods hoe could easily handle a bigger load from a higher volume 12" or 9" bucket. My buddies excavator buckets are sort of porportioned to get big bites even with small buckets - much faster. I have never checked to see if they make these kind of buckets for our small backhoes.
Larry
2012 FORD F450 XL SUPER DUTY TRUCK (A51406)
2012 FORD F450 XL...
Gas Pump Artwork (A55758)
Gas Pump Artwork...
SCAN TO RECEIVE TEXT UPDATES (A58375)
SCAN TO RECEIVE...
2019 Deere 550K (A53317)
2019 Deere 550K...
2009 International 7400 T/A VacCon V311LHA Combination Sewer Jetter Vacuum Truck (A56858)
2009 International...
2021 SAVANA 4500 BOX TRUCK (A57880)
2021 SAVANA 4500...
