How to pick up pine needles?
/ How to pick up pine needles? #1
Steve_Taylor
Twain Harte, CA
Mahindra 2810HST
I have a large pile of pine needles that I want to load into a trailer to haul away. When I try to pick up the pine needles with the FEL, I drive into the pile and tilt and lift the bucket and I get a whole bunch of needles but they don't release from the pile and they end up just falling back out of the bucket. It's the same as trying to pick them up with a snow shovel. What works is a pitch fork and I think I need something like that on the front of the bucket. I think it needs to be longer and more tips than a toothbar. Has anyone built anything like this? Any ideas on how to make one?
/ How to pick up pine needles? #2
It's not exactly what your looking for, but I remembered seeing adds for pine needle balers. Apparently it is the latest craze for landscapers. here is a link, but I didn't find any tools to pick it up loose.
Pine Straw: Harvesting
/ How to pick up pine needles? #3
Around here we let some of the 12 million foreign workers come in and bale our pine straw and sell it for $2 + dollars a bale. Keeps us from raking it up and gives the wonderful visitors from the south a way to make a living doing work Americans won't do.
WOW am I opinionated sorry about that :eek: :eek:
/ How to pick up pine needles? #4
so whats the big deal with pine straw?
its the miracle cure for which cancer?
Around here, in preparation for the high fire risk season, we are required to clear all loose pine needles and other combustibles for a distance of 100' around any structures. Living in a forest with lots of pine trees, that results in quite a lot, and we have to get rid of them somehow. I don't have enough to sell commercially but on the other hand they charge me $5/yd to dispose of them. in any event, I am looking for an easier way to load them into a trailer to cart them away.
/ How to pick up pine needles? #6
What about a leaf-Vac style system?
Suck them up.
I realize you were trying to use the FEL and looking for a way to improve that process, but i figured I would throw out an alternative.
Can you get some FEL teeth? Those, along with "fluffing" up the pile by doing several lift&dumps may help..but these are purely conjecture on my part, I have no first hand solution...except the Vac system.
/ How to pick up pine needles? #7
Couple of things, attached is a pic of my brush forks. I don't have needles but they work great on moving raked and piled native grass cuttings.
Second, as with a manure shovel, if you have deadman to ram the shovel into, usually you can get a full load. Sometimes I drop my box scraper at the pile and push into the back of it.
HomeBrew2,
I like your brush forks. Did you make them and do you have any construction details?
Unfortunately, I can't get to all sides of my pile and there is nothing to push against.
/ How to pick up pine needles? #9
Well, I thought I had a dwg file of the forks, but I'll be darned if I can find it now. Theyre about 3' long and made of 1" x 2" x .0625 tube. Yep, pretty light but they take a beating and I have a small machine. Feel free to PM me if I can help any further. Many other folks have made brush forks posts as well.
/ How to pick up pine needles? #10
Steve_Taylor said:
HomeBrew2,
I agree. Homebrew2 that looks like a very useful setup. Hmmmmm, some future project for my welding machine I think.
/ How to pick up pine needles? #11
Indeed, it's an excellent setup. In fact, all the guys that have to spend too much good money on a grapple could do exactly the same jobs with brush forks. The only exception is using the grapple pinch to yank stuff out of the ground ... that, and only that, you can't do with forks.
/ How to pick up pine needles? #12
I beg to differ -- have you ever used a grapple?
1. With proper technique, you can crush the brush into the grapple and pick up about twice the amount of brush as with simple forks...
2. Things don't tend to fall off and scatter all over the place like they do with forks...
3. You can carry an unbalanced load, which you can't do with forks...
4. You can precisely place a log or something EXACTLY where you want it, which isn't easily done with forks...
5. You can pinch logs or other things by the end and pull them out to where you can get to them, then pick them up...
I could go on and on... even more than I have. How much difference did the thumb make to your backhoe, and the kinds of things you can now do with it? The grapple functions the same way on the front of the tractor...
I understand you like your forks -- but the cat's meow for cut brush would be grapple forks, not empy forks... The rock/root grapple is a more versatile grapple overall, and the grapple bucket has it's plusses also, since you can scoop up things that would fall through the forks...
/ How to pick up pine needles? #13
Finally found the dwg plot, attached.
  • Brush Forks Model (1).pdf
/ How to pick up pine needles? #14
That is probably the biggest frustration for me. I built a 60" fork bucket with 11 tines about 30 inches long(looks similar to Homebrew's addon forks). You can just make it out in my avatar dumping onto a brushpile. It has been tremendously usefull for me and It is great for ripping out brush and scoops cut brush and branches well, but more often than not, one limb in a pile will be too out of balance or hang up on something and lever half or more of my load off of the bucket so I come away with half of what I could have had and a scattered mess of a pile.
I placed an order with Surplus Center yesterday for a new loader control valve, 3 spool with float as my original valve dosn't have float. I also ordered the cylinders, hoses and fittings for a light duty grapple I have been planning for a while. That third spool will be for the grapple and also for a hydraulic powered cement mixer I am planning that attaches out on the FEL bucket.
In the case of piled pine needles, I think the forks alone like Homebrew pictured would be very effective as not only can you scoop a ways into the pile, you can also stick the tines down into the top of a pile and rake back/separate out a nice bite sized chunk of the pile to scoop up.
I will start a thread in the build it yourself forum about the grapple build when I get started on it in a week or so.
/ How to pick up pine needles? #15
Nice long teeth work well for that too... My friend used the teeth, back-dragging, to prep for sowing fescue in areas that he'd cleared. Once he'd cleared the brush, he'd back-drag with the bucket pointed almost straight down, dragging out all the debris first and hauling it to the pile, then to scratch up the surface enough to seed it down to prevent erosion....
I'm not criticizing forks at all -- I plan to get a set of adjustable forks when its closer to building time -- only saying that the grapple can do several more things than just yank stuff out of the ground... ;)
/ How to pick up pine needles? #16
Steve_Taylor said:
HomeBrew2,
*there is nothing to push against.
*I can push things into the FEL Bucket with the front blade on my Bolens or CC Garden tractors in situations like that.
/ How to pick up pine needles? #17
I'm in the process of building a "rock bucket" out of old oilfield sucker rods, looks like it would be just the thing for compacted pine needles. (I plan on using it for hay and manure as well.)
Just as soon as I get a little welding time I will post the pics, I've got the bars all bent and just need to start tacking it together. (bending was probably the hardest part of the job!)
HomeBrew2, I sort of copied your design and made myself a set of brush forks. I have a friend who has a MIG welder and he showed me how to weld with it. I've only done Oxy-Acetylene before and I'm not very good at that. It turned out pretty well for my first such project. I used .092 1x2 tubes the steel cost $75. I also bought my friend a refill on his gas tank for $20.
Here are some pictures.
/ How to pick up pine needles? #19
I WOULD BE INTERESTED IN THE DETAILS AS WELL. MY ADDRESS IS BOB@SURVIVAL-SPANISH.COM THANK YOU
/ How to pick up pine needles? #20
I have both pine and assorted leafed trees with woods on two sides. Bought a Cyclone rake, it does great on any loose debris. Pulls behind tractor. They can attach to just about any contraption out there. I just converted mine to a x758 for this year's Foliage.
Cyclone Rake Lawn Vacuum Systems call them good bunch of people.
2x4x8 Utility (A62613)
Can Am Defender (A63688)
Can Am Defender...
2018 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A61573)
2018 Chevrolet...
2003 Tennant 7400 Compact Industrial Floor Scrubber (A61572)
2003 Tennant 7400...
Caterpillar 963 Track Loader Service Manuals (A63117)
Caterpillar 963...
Caterpillar Service Letters 1960's and 1970's (A63117)
Caterpillar...
