Problems after Norton Removal
/ Problems after Norton Removal #1
Dusty
bx22
I have dumped Norton from my computer, and now, I can't get the Smilies or the spell checker to work. Anyone have any idea as to what setting might have been changed to effect this problem. Thanks Dusty
/ Problems after Norton Removal #2
Did you doble check you editor interface under edit options. My smilies never worked until just a few days ago and I found I had to have the enhanced option selected. Maybe when you un-installed Norton it changed that settings from a shared file. Norton uses a lot of shared files.
Just a suggestion, that is all.
murph
I checked this in "Home" on the website, and nothing has changed there. I know that it has to be somewhere in IE settings, but I don't know where to look. I have checked my usage on other websites, and the problem is universal, so I know it must be in one of my computer settings. Just which one, I don't know. Nothing outside of the white box will work for me. Thanks for the suggestion... Dusty
/ Problems after Norton Removal #4
Simple fix, start using Mozilla Firefox. More user friendly, more secure, easier to use than IE and best of all it's free! You might consider giving it a try. It might not only fix your problem but you might just like it better.
/ Problems after Norton Removal #5
Please don't forget this, from what I have heard if you leave IE and go to Firefox? ya can't go back to IE.
Food for thought
Jim:)
Just found out that something has disabled System Restore. Norton is worse than any Virus out there.
/ Problems after Norton Removal #7
Food for thought
Jim:)
Not true. I have both on my computer/computers and I can go bach and forth all the time and even have both running.
murph
/ Problems after Norton Removal #8
murph
OK I wont bump heads with ya
But not my experience here
Jim
/ Problems after Norton Removal #9
Jim,
Not looking for to bump heads with anyone. I just know that your statement of not going back is not my experience. See pic attached shows both programs running side by side.
/ Problems after Norton Removal #10
Food for thought
Jim:)
I would also have to disagree. I have both on all of my computers. From time to time I also run both programs at the same time when launching web pages to my website to make sure they load correctly. In several years of use I have never seen any problem. Firefox is just a better all around program.
/ Problems after Norton Removal #11
I run both as well. I prefer Firefox. It never crashes... Whats not to like?
/ Problems after Norton Removal #12
murph
Same here, murph. Actually I use Firefox and the wife uses IE, on the same computer.
Spent 3+ hours on the phone today with Microsoft tech and still not any better. Got a cheapie HP computer today to get back on line and will still try to fix the old gal. Microsoft tech said that tomorrow, they will take charge of the computer by remote access and have a higher level tech work on it. What are your thoughts on this plan? Dumped Norton on this new computer before doing anything else. Also dumped AOL, and a few other add on programs that I have no use for. Downloaded AVG anti virus and AVG spy ware package, and found that the computer came with 3 tracking cookies right out of the box!:mad: Smilies work now.:eek:
/ Problems after Norton Removal #14
My dealings with MS and them taking control of my computer is not good. When the tech starts telling me to dump all my Internet and other settings to get access to my computer they have no clue. I have 2 firewalls to get to my computer. It would seems that is the first thing they need access to. But what do I know. :(
/ Problems after Norton Removal #15
I'll be interested to hear what happens on this, because I'm getting ready to remove Norton from my computer as well. The last time I had a major problem and had to wipe the HD, before I did I tried to remove Norton, and not only would it not complete the removal process, it kept asking for files on the Norton disc, but then would not go get them - it's a real mess. I'm planning to go to AVG as well. Hope you get it worked out, I'd hate to have to wipe the HD again..........
/ Problems after Norton Removal #16
If you did not manually purge the registry of ALL Symantec/Norton entries you did not get rid of NAV...
/ Problems after Norton Removal #17
Norton can be really hard to get rid of. Using the Windows software manager apparently has failed in many cases. I tried; it locked; then although it was still listed, I couldn't do anything with it nor could I connect to the internet. It was acting as a firewall.
Download RNAV2003 from Symantec. RNAV stands for Remove Norton Anti Virus. It will get rid of it. Btw, I could not find it on the Symantec site even though it is Symantech software. I found it somewhere else.
Spent a lot of time with the Microsoft tech guy, but still not fixed. Using another computer now, and will work on that one till it is either fixed, or I reformat the drive and start over. Waiting for a call back from next tier of Microsoft help. Glad that I am getting a free service call.
Got the call back at 12:30 AM tonight and all is well now. The original tech transcribed the wrong number, and they kept getting a "not a working number message". He told me that they then tried directory information to get the correct telephone number. Took about 45 minutes with remote access for them to figure out the problem and to reload all the files that were either damaged or corrupted. I sat there looking at the screen and watched as the cursor flew around the screen checking things off and opening and closing windows, changing settings, etc. When it was all done, everything was back to normal. I am very pleased with the service provided me by Microsoft Support. The best part of it, was that it didn't cost me a thing. I didn't know it until I called, but I have 2 free support sessions with the original purchase of Windows XP Professional. I still have one left, and this one support session is still open in the event that I find any additional problems in the future that are associated with this event. I am happy now, and can go to sleep and not think about this any longer. Dusty:D
/ Problems after Norton Removal #20
I am beginning to think that Norton is the root of all evil.
I have been getting these pop-up windows telling me that my virus protection has found a virus, but it has always been on the E: drive, my second hard drive. It makes a recommendation that you 'scan' for the source of the virus, so last night I decided to do that. It went right through C:, finding nothing, then on to E:, supposedly working in a folder called E:_Restore\TEMP. After three hours of toiling in this folder, finding some 150+ problems, it appeared to be unfinished, so I left it running and went to bed.
This morning, it was still running, having found some 750 viruses, worms, etc., still plugging away in that same folder, giving no indication of being finished, and now I noticed in the list that it had found at least two on C: even though it finished C: last night.
I decided to kill it, because if it can't do it's business in over 12 hours, it never will. Also, everything was slowed waaaaaayyyyyy down, like the processor was swamped. When I try to kill it via the button on the program screen, guess what? It hangs, just like the removal of Norton did when I tried to remove it from the ME system and I have to kill it with Task Manager.
Decide to re-boot. Shut down system, reboot.....to a black screen. Only way I can restart is through the Recovery Console of XP.
NO MORE NORTON ANYTHING FOR ME.
Asphalt Roller Tire (A68134)
Asphalt Roller...
Unused 2023 Unused Hustler LM260 Swiftblade Tractor Loader Attachment (A66734)
Unused 2023 Unused...
2004 Caterpillar 315CL Excavator (A64194)
2004 Caterpillar...
20t Ton Air/Manual Hydraulic Bottle Jack (A64557)
20t Ton Air/Manual...
2020 INTERNATIONAL MV607 REEFER TRUCK (A67714)
2020 INTERNATIONAL...
PORTA POTTY (A67714)
