Adding a 2-speed pto
   / Adding a 2-speed pto
Herewith a few pics - first one is my rig hiked up in back for this procedure.
And the view from the workbench...
With the PTO case removed you can see more hard shiny parts - Kubota's are orange inside too !
This one shows the single-speed parts. In a few hours I'll post a pic of the new parts that make the box 2-speed.
   / Adding a 2-speed pto #15
Nice shop Dick - clean and well organized. I really like your socket storage solution.
   / Adding a 2-speed pto #16
I like your lift. What model is it and where can I find one?
Peter
   / Adding a 2-speed pto #17
Dick, nice set-up. Hey just a thought, with the tractor setting up like that for a few days now, make sure your battery is'nt leaking, good get messy............
Kubmech - It does look pretty steep but the battery is dry on top - I'm not going to open any caps though /w3tcompact/icons/smile.gif
Here's a pic showing the new gears, thrust washer and inner race. The upper pinion is 2-pieces.
This went really well - here is the finished 2-speed box ready to go back on. The leftover parts to the right are the old single pinion, its gear, and the dummy spacer that's been replaced by the new gear and race.
Toughest part of the job was getting the old gasket cleaned off - they use some serious adhesive at the factory.
My new 2-speed PTO !! It's running in this shot but the camera was fast enough to freeze it.
It works like a charm. Even the slot for the pto lever is long enough so no mod was needed. Gotta get a rabbit decal to mark the high speed position /w3tcompact/icons/cool.gif
Champagne anyone? On second thought maybe I'll just have a beer.
Crown RM6025-45 4,500 LB Stand-On Electric Forklift (A59228)
Crown RM6025-45...
Unused 2025 CFG Industrial H15R Mini Excavator (A59228)
Unused 2025 CFG...
Caterpillar D5G LGP (A53317)
Caterpillar D5G...
Bush Hog 3pt 14' Mower (A53317)
Bush Hog 3pt 14'...
John Deere 5075E (A53317)
John Deere 5075E...
20.7kW Aptos 440W w/ IQ8PLUS Enphase Microinverter Solar System (A59228)
20.7kW Aptos 440W...
