Iseki TX1500_3 4.50 star(s) (2)
Information, reviews, photos, discussion topics, owner pages, and specifications about the Iseki TX1500_3.
Under 25 HP Tractors
About the Iseki TX1500_3
Iseki TX1500_3 Discussions (25)
Here are the most recent TX1500_3 topics from our community.
  1. F
    Iseki TX1500 hood wanted.
    Please let me know if anyone has a hood they are willing to part with, doesn't have to be pretty, just functional. Thanks, Mike
  2. W
    Iseki tx1500 3point
    Hi there, I have the iseki tx1500f. I got it running but I can’t get the hydraulic lever for the 3point to work. The lever won’t move at all it’s locked up or something. I’m new to this stuff so...
  3. I
    Glow spiral iseki tx1500
    Hi ! The glow eye of my iseki TX 1500 won't work properly, also the glow plugs won't heat up like they should. I placed a new glow eye, new glow plugs and replaced the wiring Involved with the...
  4. P
    Oil in radiator - Iseki TX1500, Mitsubishi engine KE75
    I checked the water level in my radiator and noticed a thin film of black oil on top of the water. Checked the water while running the engine without the radiator cap. Some air bubbles the first...
  5. D
    Iseki tx1500 fuel filter change
    I have what I imagine is an older style fuel filter chamber on my tractor which has a metal collar. It doesnt appear to have a thread to dismantle it. Can anyone advise on how I get the old filter...
  6. D
    Iseki tx1500 tappets
    Anyone have instructions on iseki tx1500 tappet adjustment? Ive managed to find a parts list and owners manual but is there a service manual out thete?
  7. marcelPL
    Connecting custom-made backhoe to iseki tx1500
    I have this custom-made backhoe that came with my iseki tx1500. From what i read on internet it is not a good thing to connect such a structure directly to the tractor. Because the tx1500 does...
  8. marcelPL
    Iseki tx1500 name of lifting arms part?
    Hi all, on my Iseki tx1500 they connected this excavator. But because of the way it is connected, one of the previous owner(s) removed the hydraulic part where the 2 lifter arms are connected to...
  9. marcelPL
    iseki tx1500 starter running slow: looking for 'grounding terminator'?
    Hi all, my name is Kaz, i live in the south of Poland, just bought 1 hectare of land, and last week i bought an iseki tx1500 (2wd) second (3rd/4th/5th) hand. One of the previous owners built this...
  10. U
    Opinion iseki tx1500 2wd
    Hello colleagues today I turn to you to get information about an Iseki tx1500 2wd, I'm thinking of buying one with a mower cutter 1 meter wide, the tractor is in impeccable condition I just want...
  11. M
    Iseki TX1500 valve seat inserts
    Does anyone know the valve recession for a Mitsubishi TX75 engine? i.e. far far above or below the head surface the valve heads should be when assembled?
  12. 6
    ISEKI TX1500 and TX1500F
    Can someone tell me what the "F" means? How can I tell what year mine was manufactured?
  13. J
    iseki TX1500 (G174) Clutch Replacement Advice Needed
    After 30 years of use its time to replace the clutch on my G174. Anyone out there with any experience on this I would welcome their input and advice. Thanks
  14. M
    valve adjustment iseki tx1500
    hello all..... New here and hoping to share my knowledge and learn from you all. I"m new to working on tractors or diesel engines for that mather but working on motorcycles for a long time now. so...
  15. Rod in Forfar
    Bolens G174/Iseki TX1500 fuel leak, tire replacements
    Ever since I removed the float bowl to clean the filter, the thing has leaked a bit. Then it drained the tank and my neighbour ran it dry, so off it came again. I tightened it carefully with a...
  16. ESBkevin
    Before I do too much damage! Iseki TX1500
    Good morning Ladies and gentlemen, further to my initial posting in the introduction thread this is my first real post, so please be gentle with me. I have bought myself the aforementioned TX1500...
  17. K
    Iseki TX1500 owner
    Hi one and all My first time on the forum. Have a request for help/advice. Will post in new thread. Nice to be here :)
  18. B
    Iseki tx1500 F (G-174)
    Looking for decals, and type of paint to retore my tractor. Thank you, Steven
  19. dantnz
    Iseki TX1500 - no drive to rear wheels
    Just had a nightmare day! Tractor stuck in a bog and now no drive to the wheel either! Drove over the area loads of times and was fine, then maybe one too many times and it just dug itself right...
  20. S
    Iseki TX1500
    I'm trying to get parts manual for iseki TX1500 coz i needed to buy spare parts. I need the parts no for the piston ring , head gusket and con rod bearing.
[ad placeholder]
User Reviews (2)
Read what TractorByNet members think about the Iseki TX1500_3 Subcompact Tractor
5
50 %
4
50 %
3
0 %
2
0 %
1
0 %
5.00 star(s)
keithf1hunting
TX1500_3 Iseki
Dependable Little Tractor
Model Year: 1979
This little tractor has way more power than your would expect, it is like a little tank. Mine has 4x4 and is unstoppable even in 2 feet of snow.
Pros: Cheap and dependable.
Cons: Hard to find parts.
4.00 star(s)
Rod in Forfar
TX1500_3 Iseki
Iseki 1500X/Bolens G174 Compact Diesel Tractor
Model Year: 1981
At 1200 pounds and another 305 for the mower, this is a substantial machine. It rides pretty well if you keep a pillow on the seat and the twin cylinder 17 makes a lot less fuss than the hysterical 18 hp Kohler single on my Simplicity riding mower. Traction is excellent in 2WD, let alone 4WD with differential lock. It's tall and looks tippy. At one point mowing across a slope under an apple tree I stopped the machine and climbed off, fearing a rollover. I lifted as hard as I could on the uphill fender, though, and couldn't budge the thing. A rear-mounted mower can do a fine job on the flat. Sharply undulating terrain, on the other hand, causes problems of geometry and unmowed patches of grass. Even with its traction problems, the Simplicity does a better job on the uneven lawn. The big problem with the Bolens, of course, is that you are cruising along with all gears turning. You aren't going to stop suddenly and back up the way you do routinely with the hydraulic Simplicity. Thus the mowing job will consist of gradual, sweeping turns, leaving a lot undone. There's a reason why the hydraulic mower has taken over the market. In the field, on the other hand, the Bolens shines. It will power through very long grass leaving the old Woods mower or the 48" rotary mower no choice but to follow along. Sharp turns swing the mower wide, and casualties among the little trees result if the operator doesn't plan ahead. 4th gear of 6 seems to be about right, and about 2/3 rpm's for the finish mower, 1/2 for the rotary. One six-acre field of seedlings has proven too closely-planted to mow with the wider equipment, so it looks as though it will belong to the 48" mower for the foreseeable future. This work involves long runs down rows of seedlings, cutting weeds out of the way. The tractor is durable. A dozen tankfuls of diesel so far have resulted in no oil consumption and no maintenance required save the replacement of the four drive belts on the mower and many blade sharpenings. One puzzling factor is the fondness of the engine for its glow plugs. It needs a full 20 seconds of pre-heating (as indicated on the cowling) even in warm weather (A starter rebuild solved that problem). The tractor's headlights are highly functional, focusing in a useful manner on where the mower will next cut. I've mowed our 2-acre lawn with the Bolens since I bought it and am getting better at it. Learning to trust it on slopes was the big thing. It can climb like a goat in 4WD as long as the mower is down. Once when the belt broke I lifted the rig and headed for the garage, up a steep slope. Not a good idea. The beast reared and pivoted 90 degrees on me before I could regain control. This is potentially very dangerous, so I added three suitcase weights for the front. That took care of the problem, even with the 420 pound rotary mower. Two weeks ago I added the 48" rotary mower for field work. After one abortive trip around the parking lot I immediately ordered an overrun clutch for the drive shaft. The single-stage clutch means that without the extra clutch the rear wheels literally won't stop until the rotary blade ceases operation. It's fine with the add-on clutch, though, and seems to have lots of power at medium revolutions in PTO range 2 (max. 700). This combination is obviously a winner for field work around little trees, because I use my other two tractors so little now that it's in the yard. That said, I can't see that this tractor would work very well on a snowblower. That's one application where you really need live PTO. As nearly as I can tell the Bolens G174 uses about 1 litre per hour when running an implement mowing. Actually, the real competition on the farm is between the Bolens and my TAFE 35 DI tractor equipped with a new Rhino 160 rotary mower. The Bolens is doing the lion's share of the mowing because it is so much handier around little trees. So the TAFE, four times its weight and twice its horsepower, complete with new canopy and expensive mower, sits in the yard while I bounce around on this handy little beast.
Pros: Powerful, durable little beast, 4WD and different lock, powerful lift on hitch.
Cons: Lack of live PTO reduces its versatility.
[ad placeholder]
Iseki TX1500_3 Owner Pages
View owner pages to see photos, customization and comments about member-owner Iseki TX1500_3s
Iseki TX1500_3 Community Rankings
#146 user rating of 731 Under 25 HP Tractors items
#477 Viewed of 731 Under 25 HP Tractors items
#87 discussed of 731 Under 25 HP Tractors items
#999 user rating of 19625 items overall
#4261 Viewed of 19625 items overall
#510 discussed of 19625 items overall
