Iseki TS1910_2 3.70 star(s) (3)
Information, reviews, photos, discussion topics, owner pages, and specifications about the Iseki TS1910_2.
Under 25 HP Tractors
About the Iseki TS1910_2
Iseki TS1910_2 Discussions (27)
Here are the most recent TS1910_2 topics from our community.
  1. A
    Iseki TS1910 glow plugs
    Hi, looking to replace the glow plugs on my TS1910, currently they have a set of JKC 10.5v 6k glow plugs that are 88mm long with a 24mm long glow element. I can't find any info on JKC plugs but...
  2. J
    Iseki TS1910 oil coming out of breather cap
    This is an Iseki TS1910, G192. I got it and it had sat for 3 years. I got it running, by a lot of cracking open fuel lines and cranking, pressurizing the fuel tank, and a little starter fluid (I...
  3. tucker2
    Oil & Fuel What type of trans/hyd fluid for Iseki TS1910
    Looking at the dipstick the oil looks like a heavy transmission type, not the thin hydraulic fluid type most newer tractors use. Does anyone know the correct fluid for the Trans/hyd. Also...
  4. M
    iseki ts1910
    hi i am new to this forum. i am owner of iseki ts 1910 and i am in a service period and i am looking for the service manual to download or some boby send with email. free or with money. sorry for...
  5. K
    Bolens G192 (Iseki TS1910) Auxiliary speed Change Lever Stuck?
    I have a Bolens G192 that sat for approximately 10 years in a barn. It only has 412 hours! With just a little TLC it is running great and I have managed to un-stick the clutch with a putty knife...
  6. D
    Steering Gear for Iseki TS1910
    Does anyone know where to find a replacement steering gear box for a Bolens G-194 or Iseki TS1910LF? Prefer a used one... or a rebuild kit/parts. Is there any Steering Box that will work on the...
  7. B
    Looking for Iseki TS1910 manuals
    Hi Guys and Gals, I just bought an Iseki TS 1910 tractor and am looking for the owners/service manual. I emailed member lens12 but haven't gotten any response. Hope he is ok. I also have a...
  8. D
    Iseki ts1910 seat
    Received a new seat for my tractor. Brackets do not match current seat. All searches bring up the same seat. Is there a different seat available for this late 70s tractor?
  9. P
    Iseki TS1910 / Bolens G192 Wheels - What other Brand Models Fit?
    I have an early Iseki TS1910, serial number 000020?. I have ag tires, I would like to get some wheels and tires better suited to lawn care, and keep the current tires and wheels. I have...
  10. H
    Newbie needs some info on a Iseki TS1910 4x4
    Hey every one. I'm new to the forum. I'm From SC. I currently don't own a tractor, but hopefully that will soon change. Been looking on the forum for info. Nice and a lot of info on here, but...
  11. R
    radiator hose - Iseki TS1910 Bolens G192
    For those looking for an upper radiator hose for a Bolens/iseki TS1910, i found a cheap alternative. i found the 2AA1 motor was put in Bobcats. That part is #A-6576028 and $6.00. Ordered through...
  12. J
    Buying Advice Bolens G192/ Iseki TS1910 front grill
    I need a front grill for a Bolens G192. If you have one or know where I can get one please let me know. Thanks!
  13. G
    Questions about Iseki TS1910 transmission
    I recently bought an Iseki TS1910 tractor. I have gone over it, repainted it, and replaced the idiot lights on the dash with gauges. The brakes are on a shaft in front of the rear axle. The seals...
  14. C
    iseki TS1910
    Where to find a new fuel filter and housing(cup)? And how much?
  15. Bull88
    Bolens G192/Iseki TS1910 Bucket Source?
    On this website, I have seen pics of TS1910s with FELs. I have a Bolens G192, which I understand is the same as a 1910. Is there a source for the bucket assemblies?
  16. K
    Iseki TS1910 Dash Lights
    What do the three lights on the right side of the dash represent? I have one coming on and want to make sure that my machine is tip top.:)
  17. RobertBrown
    Bolens G192/Iseki ts1910
    Anybody want to buy my tractor? It runs and works fine.
  18. R
    Brakes on Bolens G192/Iseki TS1910
    i didn't realize how bad i needed brakes until i hooked up a rotary cutter. Scary! Does anyone have any sources/prices for my tractor? baby needs new shoes. thanks, russ.
  19. R
    Iseki TS1910 FEL pics
    I have pretty much finished the FEL and repainted my tractor ..
  20. P
    Iseki TS1910 fuel filter
    I just took my TS1910 out of service to perform numerous service items. One was a change of the fuel filter and cleaning of the bowl. Everything went well except for the fuel filter gasket. I...
[ad placeholder]
User Reviews (3)
Read what TractorByNet members think about the Iseki TS1910_2 Subcompact Tractor
5
0 %
4
67 %
3
33 %
2
0 %
1
0 %
3.00 star(s)
taku827
TS1910_2 Iseki
Parts Availability
Model Year: 0
This tractor runs fine but leaks a great deal of oil. So far, I have been unsuccessful in finding gaskets for this tractor. Also, have worked fairly long time trying to find dealers or any other support for this unit but no luck so far. Sent 8 emails out to certain dealers but no response at all.
Pros: Runs fine, starts reliably, compact.
Cons: No power steering so very hard to turn when front end loader is full. No support.
4.00 star(s)
Welshy
TS1910_2 Iseki
Reviving Iseki 1910
Model Year: 0
I am on the road to rebuilding an Iseki TS1910. Luckily I was given a parts manual, unfortunately tho, there are no dealers any where handy. I will have to source a few bits adhoc, or build them myself as I have already done with the starter. The clutch and throw out bearing will be the next major challenge.
Pros: Easy and simple to work on.
Cons: Hard to get original parts.
4.00 star(s)
scooterseats
TS1910_2 Iseki
Iseki TS1910
Model Year: 1987
I bought this unit used from an individual that apparently never owned a grease gun. This tractor was, to say the least, neglected most of it's life. It had no brakes and had primarily been used for a bush hog. It did not have an overrunning clutch on the PTO hence the worn brakes. I have spent the last couple of months greasing and repairing linkages, bushings and yes, the brakes. It turned out that the brakes still had ample lining but the cams and shoes were worn at the contacting surfaces. I built up the shoes and cleaned and reassembled all components and have great brakes now. I have replaced the seat and while I was rebuilding the brakes I moved each fender out by 2" for added room in the operators area. It does have a front end loader and I have a 4' box blade and this is a very handy size tractor for small yard earth work.
Pros: Relatively economical small tractors.
Cons: Design makes getting on and off difficult for larger people.
Photo Uploads:
[ad placeholder]
Iseki TS1910_2 Owner Pages
View owner pages to see photos, customization and comments about member-owner Iseki TS1910_2s
Iseki TS1910_2 Community Rankings
#272 user rating of 731 Under 25 HP Tractors items
#80 Viewed of 731 Under 25 HP Tractors items
#82 discussed of 731 Under 25 HP Tractors items
#2102 user rating of 19625 items overall
#525 Viewed of 19625 items overall
#480 discussed of 19625 items overall
