Ferguson TEA-20 4.00 star(s) (9)
Information, reviews, photos, discussion topics, owner pages, and specifications about the Ferguson TEA-20.
Vintage Tractors
About the Ferguson TEA-20
Ferguson TEA-20 Discussions (1)
Here are the most recent TEA-20 topics from our community.
  1. I
    Kioti factory fill into Ferguson TEA-20?
    I'm coming up on my 50hr service and soon will have 11 gallons of perfectly good hyd/gear fluid to do something with. Donax-TD(now sprirax and approved in the Kioti manual) is what is going into...
[ad placeholder]
User Reviews (9)
Read what TractorByNet members think about the Ferguson TEA-20 Subcompact Tractor
5
44 %
4
11 %
3
44 %
2
0 %
1
0 %
5.00 star(s)
Doofenschmirtz
TEA-20 Ferguson
TEA-20
Model Year: 0
I bought this tractor at an auction. The tractor was only about 30 years old at the time but had been neglected. I figured on restoring it but found it really difficult to find parts. Over the years I managed to keep it running and useful by having an old Ford mechanic put a new clutch and pto shaft in it and a couple of years ago another independent equipment mechanic converted it from 6v positive ground to 12v negative ground and fitted it with a Delco alternator. Since the advent of the internet and online merchandising more parts are available and it is becoming easier to maintain. This year I replaced the leveling box on the 3 point and rebuilt the carb with parts I found online, I think now I will do a restore except will update ignition to electronic which is now available. Since I rebuilt the carb it starts really well.
Pros: Durable, tough old tractor.
Cons: Limited versatility due to not having live power or hydraulic remotes. Cannot find implements like a front mounted snowplow
5.00 star(s)
916
TEA-20 Ferguson
Ferguson TEA-20
Model Year: 1953
Nice tractor does all my snowplowing and moves small trailers around the property.
Pros: Small and easy to operate.
Cons: No hold on 3PT. Never designed with this feature.
3.00 star(s)
jfredere
TEA-20 Ferguson
Old Tractor
Model Year: 1951
Everything has been converted to 12v ac neg grd. from 6v dc pos. grd. Starter is 6v coil is 6volt.
Pros: Easy to maintain.
Cons: Hard to start.
3.00 star(s)
jfredere
TEA-20 Ferguson
Lot of Work
Model Year: 1951
Nice little tractor.
Pros: Parts.
Cons: Electrical.
3.00 star(s)
tea20
TEA-20 Ferguson
Old But Trusty
Model Year: 1958
Great little rig for small trails and light enough to use a come along and a high lift jack to get unstuck but yet still strong enough to haul out a few cords of wood.
Pros: Small and light.
Cons: No live PTO.
5.00 star(s)
MRTG52
TEA-20 Ferguson
Just Purchased - Have Not Used It Yet.
Model Year: 1952
Will update review after using. Newly purchased.
Pros: Size is great for a small hobby farm.
Cons: Rear hydraulics - must be neutral and foot off the clutch to operate.
5.00 star(s)
BillLove
TEA-20 Ferguson
Tea
Model Year: 1955
A classic.
Pros: Starts every time.
Cons: Hydraulics only work when the pto is on, may be a problem with my cement mixer.
3.00 star(s)
fergienut
TEA-20 Ferguson
Ferguson 1950
Model Year: 1950
This Ferguson has been hauling timber this summer; it will be plowing this fall and I plan on using it to pull my new, old Massey Ferguson square baler next summer (this baler runs with a 2 cylinder Wisconsin engine that I just purchased). Fergette, as we call her, is still original on 6 volts and I want to keep her that way. From the research I have done, it is a 80 mm engine (2080) as compared with a second Ferguson I own (purchased by my father in 1953) which is a 2085. Difference being about 7 or 8 hp more in the 2085 or about 30% more powerful. The second Fergie I own will spend the whole winter in the garage being revamped for next season. Why Fergienut? Because I drive 120 miles roundtrip just about every weekend just to sit on these tractors and spend a few hours working with them and screwing and unscrewing a few nuts on them. Eventually, they'll both look good
Pros: Good souvenirs.
Cons: Can't think of any.
Photo Uploads:
4.00 star(s)
neilibusmaximus
TEA-20 Ferguson
TEA-20
Model Year: 1952
This tractor has most of the original parts to it and it is almost 60yrs old. The replacement parts are relatively easy to get, and are well priced. One downfall to this particular model is the availability of parts for the engine. Most of the parts you can still get but some of them are no longer reproduced. The availability of junk yard parts is still there though. Overall when in good working order, this tractor is great for small applications and runs well with proper maintenance.
Pros: Compact design, three point hitch, 540 pto, easy to work on.
Cons: Adapter needed for pto, no rpm gauge, no water temp gauge.
Photo Uploads:
[ad placeholder]
Ferguson TEA-20 Owner Pages
View owner pages to see photos, customization and comments about member-owner Ferguson TEA-20s
Ferguson TEA-20 Community Rankings
#76 user rating of 679 Vintage Tractors items
#27 Viewed of 679 Vintage Tractors items
#66 discussed of 679 Vintage Tractors items
#1380 user rating of 19625 items overall
#480 Viewed of 19625 items overall
#1623 discussed of 19625 items overall
