John Deere LX178-0 4.00 star(s) (1)
Information, reviews, photos, discussion topics, owner pages, and specifications about the John Deere LX178-0.
Lawn & Garden Tractors
About the John Deere LX178-0
John Deere LX178-0 Discussions (50)
Here are the most recent LX178-0 topics from our community.
  1. Gary3x7
    LX178 Fuel Pump
    Thanks for adding me to the forum. I have a 1998 JD Lx178 that keeps killing the fuel pump. Once I install the fuel it makes a squealing sound for 30 seconds. I have put four fuel pumps on and...
  2. R
    JD LX178 Drive Pulley Removal
    Hello! New to the forum and looking for some assistance... 😩 I have a 1994 John Deere LX178 that I am working on in an effort to replace a failed water pump. To do so, I need to remove the engine...
  3. B
    LX178 Voltage Regulator Replacement
    I have an LX178 Lawn Mower that I bought new in 1992. It has mowed my lawn and pulled a small trailer occasionally. The charge light comes on erratically now and I thought it just needed a new...
  4. D
    LX178 Shuts Off After 15 minutes
    This previous post by another member explains the problem I am having with my LX178. Does anyone have a suggestion? I have also replaced the carb, fuel pump, fuel lines, filter and cap. Thanks...
  5. Aylessa
    Changing tranny fluid on a john deere lx178
    Can someone please tell me how to check and or change the transmission oil. I have Googled and YouTube everywhere.
  6. J
    1991 John Deere lx178 - Is this a water pump?
    So I just inherited a 1991 John Deere LX178 and need help identifying what the red thing is between the hoses? It has wires that are not connected and I need to figure out where those wires need...
  7. S
    Lx178 won’t start
    Have a lx 178 that has not started correctly for the past year. 12 volts to starter. Replaced starter and solenoid with spare one. Tried new battery. If tap starter a bunch of time it will start...
  8. L
    Help me pick my first JD: LX176, LX178, X300 or GT225
    Hi All - Been creeping in the shadows on the site for a long time and its finally time for my first question - please be gentle :eek: I bought a house with about 3/4 an acre that needs cutting...
  9. T
    LX178 Won't stay running after starting
    Hi, It's been a lot of years since my last post, still have the same 1996 LX178. This year I did full maintenance, changed trans oil, coolant, new plugs, belts for the deck, shined it up like...
  10. P
    LX178 PTO clutch - spline pin and bolt tension?
    Just replaced the water pump on this beast tractor and a couple of questions has arisen before mounting the clutch assembly. On the innermost pulley, is there only a pin half the length of the...
  11. P
    Replacing water pump on LX178?
    Hello, good folks. Got a hand-me-down 1991 JD LX178 with the water-cooled Kawasaki FD440V engine. Upon finding oil with milkshake texture and searching the web, I have come to learn that the...
  12. P
    Mowing Replacing water pump on LX178?
  13. K
    John Deere LX178 Ignition Module Needed
    I need an ignition module for my 1992 LX178. It's my understanding module from a 285 320 345 425 LX178 LX279 F725 F911, is the same. Any help would be greatly appreciated.
  14. K
    LX178 Starter Issue
    I have a 1992 LX178 and now the starter won't engage. It keeps blowing a 15amp fuse every time I turn on the key. I have a new battery and battery cables. I put in a new fuse, left the ignition...
  15. J
    LX178 No Instrument Panel Lights
    I have no instrument panel lights. Headlights turn on, two 15A fuses are ok. PTO switch is off. Got it home today from JD dealer where they replaced both coils. Ran fine long enough to cut half...
  16. K
    LX178 Parking Brake
    LX178 Parking Brake (REVISED) Mower set outside all winter and now I can't seem to get the parking brake to release. I've tried 6 or 7 times to reset and release to no avail. Any help would be...
  17. K
    LX178 Throttle Control
    I have a 1998 LX178 and have just overhauled the carb. My throttle lever on the dash has always only gone forward halfway. It seems to me that's the fast idle location. Should the lever go forward...
  18. S
    LX178 John Deere
    hey guys ,,, I have a LX178 John Deere , was wondering if anyone could tell me if there is a site where I can get a free download of a service manual for this lawnmower ? any help would be greatly...
  19. K
    LX178 Lift Assist Very Stiff
    Is there an adjustment for the lift assst. Mine is so hard I have to nearly get off the tractor and use both hands to move the lever forward or back. I wouldn't think it should be this hard to...
  20. K
    Looking for a source for LX178 parts
    I had a '93 LX178 given to me and I'm lookng for a source forparts. I replaced the aftermarket electric fuel pump and cleaned up some wiring. It runs full throttle OK but idle is bad. Started off...
[ad placeholder]
User Reviews (1)
Read what TractorByNet members think about the John Deere LX178-0 Subcompact Tractor
5
0 %
4
100 %
3
0 %
2
0 %
1
0 %
4.00 star(s)
mr5by5
LX178-0 John Deere
Good Machine for the Right Price
Model Year: 1998
I was very pleased with the '78 John Deere 212 tractor we bought used back 1999. After over 30 years of work, though, the engine was starting to use oil and the mower deck was almost beyond repair. I considered buying a new J.D. but anything comparable to the rugged construction of the '78 212 was priced out of my budget. The local J.D. dealer had several used tractors they had taken in trade and the asking price on the '98 LX178, which seemed to be in good shape, was reasonable. This tractor must have been used mostly for snow-blowing (even though it did not come with the blower attachment) since the small mower deck was in "like new" condition. It did a beautiful job of mowing our "rough" 2 acre country yard until cold weather set in in the fall, then it would not start! I found the choke linkage was totally mis-adjusted and a few tweaks put that back in order. It ran well, then for the rest of that season and part of the next, then the fuel pump went on it! The J.D. parts price on a replacement for the mechanical fuel pump on the Kawasaki Twin engine was ridiculous, so I shopped around and found a electric fuel pump that works great for about 1/3 the price. Early this season the electric PTO clutch for the mower drive crapped-out, another expensive piece from J.D. without many alternate sources. I also replaced the main drive belt, mower-to-deck belt, and internal deck belt at that time. The design of the older models is much sturdier than the new "standard" ones and I would highly recommend anyone needing a reliable tractor to shop-around for an older used J.D. like this one as opposed to buying an inferior brand. I have lots of money in the bank to buy parts for this tractor that I could have spent on a new one! So here are the weak-points of this model to date as I see it: - Fuel Pump - Mower Clutch - Governor surges at low engine speed (even tells you that in the Manual!) - "Mower Deck "bounces" on rough surfaces, latching deck in "travel" position. I have a cheap "fix" for this: go to the H/W store and buy a PVC pipe cap that is just the right size to fit over the lift lever handle for the mower. (I think the one I have is 1 1/4-inch). When you lower the deck to cutting position jam the pipe cap onto the handle to hold the release button on the lift lever down. The mower will then "float" with the terrain and not "latch" itself in "travel position" every time you hit a bump! - I also want to replace the battery with a small automotive battery mounted in a box hanging from the front axle. This should give me added weight on front wheels to improve steering on slick grass, while providing a more reliable battery than the teeny tractor battery that fits in the factory battery box.
Pros: Reasonable price, nice-running engine, rugged hydrostat trans.
Cons: Engine fuel pump, electric clutch for mower deck Is expensive to replace.
[ad placeholder]
John Deere LX178-0 Owner Pages
View owner pages to see photos, customization and comments about member-owner John Deere LX178-0s
John Deere LX178-0 Community Rankings
#196 user rating of 2962 Lawn & Garden Tractors items
#1710 Viewed of 2962 Lawn & Garden Tractors items
#29 discussed of 2962 Lawn & Garden Tractors items
#1380 user rating of 19625 items overall
#7364 Viewed of 19625 items overall
#292 discussed of 19625 items overall
#11 Ranking of Most-OwnerPages in 19625 items overall
