Case-IH 585_2 5.00 star(s) (2)
Information, reviews, photos, discussion topics, owner pages, and specifications about the Case-IH 585_2.
50-100 HP Tractors
About the Case-IH 585_2
Case-IH 585_2 Discussions (24)
Here are the most recent 585_2 topics from our community.
  1. K
    Case IH 585 drive gear at clutch
    Any one got experience with drive gear
  2. moochie2510
    Case IH 585
    How to replace drive gear on the shaft coming from clutch and the driven gear on main shaft?
  3. Jrasband
    No power steering Case IH 585 MFWD
    I need to get this tractor fixed up so I can sell it. Before I got the Kubota, the LS was in the shop for a year and a half the Case IH was all I had. Well I was using the tractor every day in the...
  4. Jrasband
    Help me value my Case IH 585 for sale
    I am ready to sale my Case IH 585 tractor now. I am hoping that folks who have thoughts on what they think this tractor is worth will give me feedback. I have had it for about a year. I bought it...
  5. Jrasband
    Power steering cylinder seals Case IH 585 MFWD
    I thought I would put a post here to see if anyone can help me. I am looking for power steering cylinder seals for my tractor. I have found them on the cnh website and a dealer can get them for...
  6. Jrasband
    new rims for case ih 585 mfwd
    I am looking for replacement front outer rims for my Case Ih 585 MFWD. This is the style that I am talking about -...
  7. Jrasband
    Case IH 585 hard to shift
    I am wondering if I can improve the shifting quality of this old tractor. Shifting low,high, reverse lever is much easier than shifting the gear lever. foward reverse lever can be trickey to get...
  8. Jrasband
    Case IH 585 no start
    Was plowing snow today with scrape blade when the tractor suddenly stopped running. I believe it to be fuel related as it put out a little smoke, coughed and ran out of power as it was dying. I...
  9. A
    Case ih 585 wiring issues
    Hi all new to this but I知 looking for a wiring diagram for a case ih 585 xl I have brought 2 different manuals but neither have the wiring diagram any help would be much appreciated
  10. S
    Case IH 585 parts
    I'm looking for some body Parts for a 585 that are proving somewhat hard to find. Below is a list of items that I would like to track down for my tractor: 1) instrument panel housing (1500974C4)...
  11. J
    Loader 89 case ih 585
    We have a low hour case 585 that we have had since new. The only thing we do with it is brush hog and moving stuff around with the bucket. The bucket hydraulics got so you needed to keep the...
  12. I
    Case IH 585 where to hook up hydraulic spool valve
    I am adding a two spool valve to my Case IH 585 and need to know where to tap into the hydraulic system to attach the supply and return for my new valve. Thanks.
  13. J
    Case IH 585 60hp Tractor Need Operators Manual
    Hi, I just but a Case IH 585 and I need an operators manual for it. If you have one that you can copy I would be willing to trade a copy of the service manual I have for it. Thanks, Joe C.
  14. T
    Front-End Loader Case IH 585 loader/backhoe attachment?????
    I have a Case IH 585 that I want to install a loader on. I found a older Case 210 B-C with a loader and backhoe. Would the loader/backhoe attachments fit my 585?????
  15. D
    IH 585 hydraulics
    Hi All having problems with the fore loader on the above tractor in that it will not lift any weight,it will lift but only when revved highly.I have replaced the pressure valve and seals on the...
  16. T
    Case IH 585 wireing diagram
    Hi, I've got a Case 585 that had a short that burned the wireing. I'm looking for a diagram of the wireing so I can rewrite it. Any info would be great. Thanks Tony
  17. D
    case Ih 585 loss of power and blowing black smoke.
    I am having some issues with my 585. After running for a couple hours, it will loose power and start blowing black smoke, If i mash the clutch in it will rev back up and the exhaust will clear up...
  18. S
    case IH 585 bad engine?
    I've got a caseIH 585 that has a serious rumble over 1200rpms and oil pours out of the rear main seal. I'm thinking main bearings. Any thoughts?
  19. S
    Case IH 585 vs Ford NH 4630
    I am considering between these two tried and tested work horses. Does anyone have any pros and cons for either tractor? I am mainly looking for a 4x4 with a loader.
[ad placeholder]
User Reviews (2)
Read what TractorByNet members think about the Case-IH 585_2 Subcompact Tractor
5
100 %
4
0 %
3
0 %
2
0 %
1
0 %
5.00 star(s)
holt50
585_2 Case-IH
Me and My Case
Model Year: 1987
I use it to farm. I mow, bale, and feed with it. All I have done to it is change oil & FILTERS regular and put 2 clutches in. It's got around 9000 hrs. and keeps a loader on. Only thing I would want is a few more horsepower.
Pros: Reliable.
Cons: Could use another 5 horses.
5.00 star(s)
mcasey
585_2 Case-IH
Work Horse
Model Year: 1991
Tractor does everything I need it to do. Has a front end loader. More tractor than I need, but it works for me.
Pros: Plenty of power.
Cons: Little hard to mount and dismount.
[ad placeholder]
Case-IH 585_2 Owner Pages
View owner pages to see photos, customization and comments about member-owner Case-IH 585_2s
Case-IH 585_2 Community Rankings
#1 user rating of 1508 50-100 HP Tractors items
#195 Viewed of 1508 50-100 HP Tractors items
#69 discussed of 1508 50-100 HP Tractors items
#1 user rating of 19625 items overall
#1407 Viewed of 19625 items overall
#524 discussed of 19625 items overall
