John Deere 5200_2 4.00 star(s) (2)
Information, reviews, photos, discussion topics, owner pages, and specifications about the John Deere 5200_2.
25-50 HP Tractors
About the John Deere 5200_2
John Deere 5200_2 Discussions (11)
Here are the most recent 5200_2 topics from our community.
  1. M
    Replacing SCV with joystick for FEL
    On my JD5200 I have problems with my loader. It is slow, goes down on its own, and tilts forward sometimes. I would like to replace the SCV, cables, and joystick with an aftermarket hydraulic...
  2. D
    John Deere 5200 price?
    Buddy of mine is looking at a used tractor. 1994 John Deere 5200. 1300 hrs. 520 loader. bush hog 296 cutter. Tractor, loader and bush hog appear to be very well taken care of. Everything I have...
  3. J
    John Deere 5200 419 Loader - SCV Joystick Piston Repair
    I recently broke one of the crappy original plastic pistons in my loader joystick and figured I could buy the parts and fix it myself. It didn't seem too complicated but there is one thing that...
  4. P
    adding 3rd function to John Deere 5200 front loader
    I have a JD 5200 with added 521 front loader. I want to add a 3rd function to the loader to operate a hydraulic rotary cutter. Can someone help me find the parts I need to make this happen. The JD...
  5. T
    John Deere 5200 4x4 brake pedal will not go down
    if I push on the brake pedal it will go down if I really stand on it,and the brakes will work but I mean really stand on it,but to release the brakes I have to grab with both hands and pull it...
  6. J
    john deere 5200 problems
    Does anyone have any suggestions on how to get my tractor started. its a 1997 5200. I replaced battery and it still wont start. It doesnt click or do anything? Not even try to do anything. It...
  7. B
    John DEERE 5200 tractor keeps moveing after cluch is pressed.
    My John Deere 5200 tractor keeps moveing when I press the cluch in and apply the brakes. Happens when the tractor has a load on its. Anyone have this problem with there 5200?
  8. T
    Hyd on JD5200 tractor
    I recently purchased a 1996 John Deere 5200 tractor, it has a 3pt hitch but no hyd. I have talked with 3 different dealers and have received 3 different answers. One said it cannot be done, that...
  9. F
    John Deere 5200 Parts
    I have a Deere 5200 and need to replace a few body parts. Does anyone know where I may find the left and right screens, or the left or right engine covers? I appreciate any help. Thanks, Fred
  10. F
    John Deere 5200
    I just bought a 5200 with 820 hours on it. Does anyone have any advice on care/maintenance etc. I am new to caring for a deere! Fred
  11. Agrantina
    John Deere 5200 $$
    What is a John Deere 5200 2wd with 689hrs on it worth? It has draft and rear rear remotes. Orignal owner might be selling it and it has been in the barn since he bought new in 1993.. I have used...
[ad placeholder]
User Reviews (2)
Read what TractorByNet members think about the John Deere 5200_2 Subcompact Tractor
5
0 %
4
100 %
3
0 %
2
0 %
1
0 %
4.00 star(s)
mark1092
5200_2 John Deere
Average
Model Year: 0
High RPM to get the rated HP output. Not much on the torque end. Transmission sometimes sticks in high second. Has to be forcefully pulled out of gear and then works for a while. There is no predicting when it will happen again. Starting to suspect problems with the brakes. Tractor acts like the brakes are dragging all the time. It will not coast down an incline when the clutch is depressed or the transmission is shifted to neutral but just come to a stop like the brakes have been gently pressed.
Pros: Economical fuel usage, comfortable ride.
Cons: If you don't tie the lift linkage together it will bounce off the rear tires when not attached to an implement.
4.00 star(s)
1ray
5200_2 John Deere
JD model 5200
Model Year: 1996
One of the best running and strongest diesel tractors I have ever owned. Very pleased with this machine.
Pros: Starts easy and runs good.
Cons: None.
[ad placeholder]
John Deere 5200_2 Owner Pages
View owner pages to see photos, customization and comments about member-owner John Deere 5200_2s
John Deere 5200_2 Community Rankings
#547 user rating of 2355 25-50 HP Tractors items
#2076 Viewed of 2355 25-50 HP Tractors items
#325 discussed of 2355 25-50 HP Tractors items
#1380 user rating of 19625 items overall
#8981 Viewed of 19625 items overall
#778 discussed of 19625 items overall
#11 Ranking of Most-OwnerPages in 19625 items overall
