John Deere 5200_2 Reviews
4.00 star(s)
mark1092
5200_2 John Deere
Average
Model Year: 0
High RPM to get the rated HP output. Not much on the torque end. Transmission sometimes sticks in high second. Has to be forcefully pulled out of gear and then works for a while. There is no predicting when it will happen again. Starting to suspect problems with the brakes. Tractor acts like the brakes are dragging all the time. It will not coast down an incline when the clutch is depressed or the transmission is shifted to neutral but just come to a stop like the brakes have been gently pressed.
Pros: Economical fuel usage, comfortable ride.
Cons: If you don't tie the lift linkage together it will bounce off the rear tires when not attached to an implement.
4.00 star(s)
1ray
5200_2 John Deere
JD model 5200
Model Year: 1996
One of the best running and strongest diesel tractors I have ever owned. Very pleased with this machine.
Pros: Starts easy and runs good.
Cons: None.
