Ford 4630_2 4.50 star(s) (4)
Information, reviews, photos, discussion topics, owner pages, and specifications about the Ford 4630_2.
50-100 HP Tractors
About the Ford 4630_2
Ford 4630_2 Discussions (35)
Here are the most recent 4630_2 topics from our community.
  1. J
    Ford 4630
    Does anyone know if my Ford 4630 tractor has an open center or closed center hydraulic system?
  2. P
    ford 4630 alternator
    So i was having a charging issue on my 4630 and i traced it to the alternator. When putting the new alternator in i reversed the battery by accident. Quick spark when attaching the leads. So I...
  3. G
    Ford 4630 MFWD front axle problems
    I have an early 90's 4630 MFWD with a bad front axle. It looks a though the axle has been replaced previously, possibly with an incorrect part. There is a "FWD Factor" of 1.3652 located on the...
  4. J
    Ford 4630 tool box
    Ford New Holland 30 series tractors (4630, 3930, etc.) offered an optional tool box that mounted on the right side of the tractor just behind the fuel filters. The assembly consisted of a metal...
  5. I
    Ford 4630 Engine Speed
    Hello and thanks in advance, My 4630 diesel runs fine but it will not maintain engine speed. After setting the RPMs it almost immediately throttles down. This is under load i.e. mowing, etc. When...
  6. L
    ford 4630 no start
    hello, im currently working on a ford 4630 tractor. i dont know to much about tractors in general but the issue im having i figured wouldnt be much different than a car. This tractor was running...
  7. houser52
    Ford 4630 Steering Problems
    My dad has a 4630 that is about 20 years old and it has given him great service until now. Just recently the steering has been giving some trouble. When turning the steering wheel the front...
  8. P
    ford 4630 questions
    So i just came to own a ford 4630 4wd no cab and have a few questions/issues. For the most part the tractor runs really nice. I want to change all the fluids/ filters in it. The manual calls...
  9. H
    Ford 4630 Power steering problems
    ok guys I am a newbie to the site but not for working on tractors. I need some help. I have a 1992 ford 4630 FWA with power steering problems. First it was leaking fluid bad so I bought a kit for...
  10. M
    Wiring Schematic 97 New Holland/ Ford 4630
    I am in need of a wiring schematic 1997 4630 New Holland/ Ford tractor 2wd, thank you in advance.
  11. M
    Ford 4630 steering problems
    Hello. We have a non turbo 4630 w/FWA and hydrostatic steering. When tractor is cold the steering wheel will not stop rotating at the 'stops' will just keep turning. After it is at operating temp...
  12. S
    Ford 4630 oil leak
    I am looking at purchasing a 1995 ford 4630 4wd with a 7310 loader. The issue is that it has a oil leak on side between the transmission and rear housing. Since it has to be split at this point...
  13. wareagle50
    Whats a good used Ford 4630 worth???
    Have a chance to buy a 4630 from my wife's uncle. Its been very well maintained and has a Woods FEL with bucket and forks. Not sure about the hours but its a very clean 2wd with at least one...
  14. M
    Ford 4630 compression
    Hi everybody;just joined tonight after following forum for a year+. We have a Ford 4630 w/ non turbo 201" engine thats showing some age. Blow by and some oil use. Ran a compression check today...
  15. S
    Ford 4630 Hydraulic Questions:
    Hello all: I've got a Ford 4630 with a Bush Hog brand 2425QT Loader and a 3rd function valve for remote hydraulics on the rear of the tractor. The 3rd function valve has a history of blowing...
  16. J
    ford 4630 leaking gear oil
    i work for a rv dealership and we use our tractor for pulling campers around. here lately we have nocticed that our ford 4630 is leaking gear oil from around the gear box with no signs of where...
  17. T
    TN60 versus Ford 4630/3930
    I'm looking for a 4wd tractor for haying with a JD336 and a wagon, level and sloping fields. Would appreciate some opinions on the New Holland versus the older Ford/New Holland tractors. TIA.
  18. B
    Ford 4630
    My ford 4630 will not get fuel to feeder screw. squirts out a small bit occasionally. cranks off starting fluid. was wroking ok untill i changed fuel filter.
  19. H
    Ford 4630 Leaking PTO Shaft Seal
    Is the 4630 a simple remove cover and replace seal -or- does it require shaft removal and dealing with thrust washers like I'm reading about on the similar active thread for the 3000 model? Shaft...
  20. SatelliteFarms
    Ford 4630 hydraulic pump leak
    I recently purchased a 1990 Ford 4630 with 1000 hours. There appears to be fluid leaking from the hydraulic pump where it meets the case. There doesn't appear to be a gasket. Is one required? any...
[ad placeholder]
User Reviews (4)
Read what TractorByNet members think about the Ford 4630_2 Subcompact Tractor
5
75 %
4
0 %
3
25 %
2
0 %
1
0 %
5.00 star(s)
Anonymous Poster
4630_2 Ford
Ford 4630 Turbo
Model Year: 1997
I bought this used with 900 hours on it at 15 years old. Simply put, it has been a " peach." I am in the market for an 80-90 horsepower 4-wheel drive cab tractor, but I will never trade this one in or part with it. It's used for hard farm work and performs beyond expectations.
Pros: Well built and powerful
Cons: None come to mind
5.00 star(s)
lloydnelms
4630_2 Ford
4630 FORD
Model Year: 1993
Have been around dozens of Ford tractors and they just suit me...doesn't mean its for everyone. The 4630 may be the best one. Uses no oil, no leaks, no problems, a joy to operate. If I had to do it over I might have bought one with a shuttle shift. Would have also liked to have had the model with the optional hydraulic pump. This tractor is a handy size---big enough to pull a baler, small enough to be nimble and rake and tedd. I also own a 5610, and a 5640 and have been happy with them as well. My father has a 3000, 4610SU, 6610 and a 5635 New Holland.
Pros: Pulls really well, plenty of power and traction, handles well, comfortable.
Cons: Hydraulics plenty for equipment, but a little slow for a loader.
3.00 star(s)
jounama20
4630_2 Ford
Tractor Purchase
Model Year: 1999
Having owned a John Deere 1850 for 22 years, wanted to purchase tractor with cab and four wheel drive for 20,000 dollars with 3,000 hours with fel, bucket, and forks. I like it's comfort and power.
Pros: Comfort, power, and shuttle system.
Cons: Nothing.
5.00 star(s)
tractorsanmore
4630_2 Ford
4630 2 wheel drive utility tractor
Model Year: 1990
This was my first tractor . Bought it new ( left over demo ) I bought this tractor to mow around 60 acres per year . The tractor has 55pto hp .and I use a 6 ft mower . Should have bought a 7 or 8 ft mower , as it pulls this mower thru heavy grass or very tall weeds , sometimes as high as the exhaust stack with little effort . Never overheats . The tractor has the extendable lower link ends and the adjustable pin style sway control linkage , so hookup to any 3 pt equipment is easy . Tractor still runs as good as it did when it was new . Simple to service and very reliable .
Pros: Simple to work on , low cost , and no electronics
Cons: none
Photo Uploads:
[ad placeholder]
Ford 4630_2 Owner Pages
View owner pages to see photos, customization and comments about member-owner Ford 4630_2s
Ford 4630_2 Community Rankings
#146 user rating of 1508 50-100 HP Tractors items
#46 Viewed of 1508 50-100 HP Tractors items
#45 discussed of 1508 50-100 HP Tractors items
#998 user rating of 19625 items overall
#422 Viewed of 19625 items overall
#393 discussed of 19625 items overall
