John Deere 2_90 5.00 star(s) (1)
Information, reviews, photos, discussion topics, owner pages, and specifications about the John Deere 2_90.
25-50 HP Tractors
About the John Deere 2_90
John Deere 2_90 Discussions (31)
Here are the most recent 2_90 topics from our community.
  1. D
    Looking for JD 4610 power reverser owners in Northern California
    I am requesting someone in the Northern California area near Auburn allow me to compare one or two items on your tractor with mine. My tractor was disassembled and I am trying to piece it back...
  2. D
    2002 JD 4610 help request
    I bought a used 4610 while deployed overseas, my handyman back in the states ended up blowing the engine (connecting rod thru the crankcase) Long story short when I returned home two years later...
  3. D
    Need John deere 4610 help
    I was stationed overseas for 4 years, meanwhile a handy man hired to maintain my property back in the states, blew the engine in my JD 4610. When I returned home I found it completely...
  4. Kenny Tucker
    John deere 4610
    What year was my tractor Serial number LV4610H260528
  5. kcjengr
    JD 4610 - No Tilt Function on Loader
    So today I let my neighbor use my JD 4610 tractor to pull some junk out of the woods, and for some reason half way through the job the tilt function on the JD 460 loader quit working. I checked...
  6. S
    JD 4610 - first tractor?
    Hi, I have the chance to pick up a nice John Deere 4610 for sale. I see this tractor was only produced for a couple years before the 20 series was produced. Any concerns over a ten series vs a...
  7. B
    John Deere 4610
    I was bushogging on my property yesterday and saw hydraulic fluid coming from underneath the tractor. Shut off the bushhog and made it back to my barn. When I got there I had lost quite a bit of...
  8. R
    JD 4610 throttle
    How do I adjust the throttle tension? The throttle moves from desired rpm to idle when operating.
  9. 1
    3rd function JD 4610
    I recently bought a grapple bucket for my 2004 JD 4610. My hydraulic manifold has 7 ports. 4 are for the dual function loader (up, down, dump, curl), two are capped off, and on goes to the 3...
  10. rkncirclec
    JD 4610 honking/squeaking noise at startup
    When I start my JD 4610, I have a honking noise coming from the left side of the tractor next to the hydraulic filter. Operationally, everything seems fine. No leaks. I did not run over a chicken...
  11. rkncirclec
    JD 4610 No Start. Baffled
    I have a JD 4610 PowerReverser/Diesel/RearPTO. When I turn the key, it just clicks, does not start. Knowns: a) Starter Motor and engine work (we jumped the starter and fired right up); died in...
  12. S
    JD 4610 Codes
    Can someone tell me what it means when my code light flashes; short , short, long, short. Everything seems fine but this flashing bothers me. Thanks in advance.
  13. D
    John Deere 4610
    Tilt wheel will no longer lock in place and just flops, what is broken and how difficult is it to repair? Dennis J
  14. P
    jd4610 W/460 loader comeing off back posts
    I was scraping off a concrete parking lot today had about 6" of silt run off on it hit a new section of concrete and loader frame hopped off the mount and came up in the seat with me backed up and...
  15. T
    JD 4610 strange hyd problem
    Hello and happy Friday to all. My JD 4610 has a weird problem. If I operated the rear HYD for a while, say scraping or mowing, or any condition that requires the selector switch to be set for rear...
  16. T
    JD 4610 starts, but that's about all
    my 4610 4WD with power reverser has been sitting since late summer and I went to do some work and at first the hydraulics were erratic. This has blossumed to no motion in forward or reverse, no...
  17. J
    JD4610 and Case IH 8420 Baler ... HELP!
    I own a JD 4610 Tractor and I want to pull a Case IH 8420 Round baler with it ... according to tractor and baler specs I am ok. But the owner of the baler is telling me my tractors hydraulic...
  18. X
    Price Check Pricing a JD 4610 w/backhoe
    I'm considering purchase of a used 2004 John Deere 4610 4x4 from a private party. They are asking $25K and I'm wondering if this is a reasonable price. Here's the specs and included implements...
  19. L
    3-Point Hitch JD 4610 3PT problem
    Looking for some help on a 3PT issue. I have a 2003 JD 4610. When I move the 3PT lever to the full up position the hydraulic pump does not release and places a continuous load on the engine...
  20. L
    Good deal on used John Deere 4610?
    I am considering buying a 2004 diesel 4610 with 400 hours, hydraulic mid and rear pto, post hole digger, bucket, blade and brush cutter - asking price is $22,000. Can you tell me if this is a...
[ad placeholder]
User Reviews (1)
Read what TractorByNet members think about the John Deere 2_90 Subcompact Tractor
5
100 %
4
0 %
3
0 %
2
0 %
1
0 %
5.00 star(s)
OleMiss
2_90 John Deere
John Deere 4610
Model Year: 2004
Pro's - Love the engine, instant starting in very cold weather, love the 4wd, hydrostatic trans is awesome, very good on fuel, easy to maintain and service, Con's - Plastic hood will break, if you pull yourself up and down on the plastic fender all the time it will break the fender where it bolts up, very poor service in my area, parts are very expensive, the 3 pt hitch adjustable brace arms are very cheap and will wallow out and eventually break, I replaced mine with the new round arms...so far so good. Overall, I'm happy with my JD and would purchase again.
Pros: Love the engine, instant starting in very cold weather, love the 4wd, hydrostatic trans is awesome, very good on fuel, easy to maintain and service,
Cons: Plastic hood will break, if you pull yourself up and down on the plastic fender all the time it will break the fender where it bolts up, very poor service in my area, parts are very expensive, the 3 pt hitch adjustable brace arms are very cheap and will wallow out and eventually break, I replaced mine with the new round arms...so far so good.
[ad placeholder]
John Deere 2_90 Owner Pages
View owner pages to see photos, customization and comments about member-owner John Deere 2_90s
John Deere 2_90 Community Rankings
#1 user rating of 2355 25-50 HP Tractors items
#1971 Viewed of 2355 25-50 HP Tractors items
#195 discussed of 2355 25-50 HP Tractors items
#1 user rating of 19625 items overall
#8071 Viewed of 19625 items overall
#436 discussed of 19625 items overall
