ZTRs on hills & slopes
   / ZTRs on hills & slopes #11
Steep hills I mow up the hill, back down and drive up. ZTR's are a bit tricking when first learning. No traction = no brakes or steering but boy what a ride. Some of the rides I have been on require about three beers to recover.:D
It's a full six for me Giz!
   / ZTRs on hills & slopes #12
HOLY CRAP! Would like to have seen one of them. :) :) I bet the thought of them is funny now but wasn't at the time.
As much as I hate the uncontrolled rides I am not giving up my ZTR any time soon.
   / ZTRs on hills & slopes #13
Besides it's the only lawn mower that can spin donuts in my gravel driveway! Although I may have to give that up now that I'm loading my tires.
   / ZTRs on hills & slopes #14
Hi
I have some very practical experience with ZTR's on slopes/hills. I had one of the light weight models ie the one's for less than $4000. No control, and about useless on my slope in the yard going up, down or sideways. Up is about the only way to control it.
I like the speed so I set about talking to commercial mowers that had been doing it for 15 or more years.
Long story short - I now have a Kubota zd 326 commercial with a 60" deck. It basically goes where I want it to with no issues. I mow ditches with 22 degree slopes sideways - no slip. I assume if it was wet I would slip. This thing goes anywhere. Clears grass like crazy - mowed through 18" stuff no issue.
Anyway I choose the Kubota over the Deere only because of physical size. Both seemed really good.
I recently posted issues with my new 3720 on my same slopes. After adding the ZD326 to my equipment I now can mow everything I want to when I want too as each machine has its place. The ZD for yard and slopes, the 3720 for everything else so I stay nice and clean and cool.
You need to go try one of these larger machines, I had the opportunity to try one at a dealer that ditch slopes steeper than mine - he so go right ahead you are not going to tip it, I also could go down and slow up fine at the bottom.
Bob
   / ZTRs on hills & slopes #15
Bob,
The two things that make a ztr good on slopes are center of gravity and weight on the rear wheels.
My machine will go down slopes but with my light body I loose traction on the uphill tire.
After loading the rear tires things seem much better but I've only mowed with it once. I did do a 20+ degree slope ok.
Rob
   / ZTRs on hills & slopes #16
I have the optional weight bracket on my JD ztrack 757. I have not put any weights on it. With the bagger full on much of a hill - i will pull the front wheels off the ground.
I need to put that back on my project list.
D.
   / ZTRs on hills & slopes #17
Where I live we have extensive hills. One thing that turned me a bit off to the ZTR concept was, in fact, their performance on very steep hills. ZTR's are generally wide in back and have a tremendously rear-favoring weight distribution. Thusly, they perform well on hills that are reasonable. Unfortunately, when the hillside is wet or very steep they can seem like they are doing well then suddenly let go. I have had this happen two or three times in my ZTR mowing career and it is frightening. My experience with the type mowing I do is that a very efficient tractor, like an X series JD for example, will mow at a comparable pace to a ZTR unless the plot is obstacle laden. I have been able to reproduce these results time and again over the years on hilly properties I mow. True, the ZTR is faster but not that much faster. As a result, many of the professional mowers here use X series or equivalent tractors for mowing or they invest in a front cut. Unfortunately, front cut JD's are extremely expensive and have a pitiful resale value due to competition from ZTR's over the years. JD still makes them, and there must be a reason for that. I would say using both a ZTR and a front cut (never owned but used the latter) the front cut is a Cadillac to operate. Super smooth riding and cuts great. Maybe our OP could find one of those.
John M
   / ZTRs on hills & slopes #18
John,
I've learned to 'read' the ground when I'm on the ztr. If I had it to do again I think I problably would have gone with a 500 or 700 but this is what I have. I go very slowly on the few hills here (most of my land is pretty level) since my ZTR got away from me when I first got it. Now the tires are loaded and I'll go out and test it more today.
If I don't feel safe it will go but the last time I mowed it did seem much better but the ground has been extremely dry here this spring so it's hard to tell. The reason I like the ZTR is the many obstacles I have and for this it can't be beat.
Rob
   / ZTRs on hills & slopes #19
I have a 445 JD and it does a good job on hills as long as you try to keep the front end pointed up hill, and I try to keep the head of the engine on the up hill side and be prepaired to dive down the hill if it starts to slip to much. I have consider loading the tires. Maybe that would be a good thread loaded the or no? Z mower take a little different techique than a conventional lawn mower and I wouldn't go back for nothing but I would trade up.
   / ZTRs on hills & slopes #20
The new 900 series JD's are supposed to be better on hillsides with the more responsive levers and better dispersion of hydraulic flow. I have not used one, but I hear they are great on even pretty steep hills. They might turn out to be the better ZTR choice for those needing to operate a ZTR on hills.
John M
2023 54' Hooklift Dumpster 15 Cubic Yard (A55788)
2023 54' Hooklift...
2016 WESTERN STAR 5700XE TANDEM AXLE SLEEPER (A54313)
2016 WESTERN STAR...
2005 INTERNATIONAL 4300 24FT BOX TRUCK WITH TRANSLUCENT ROOF (A54313)
2005 INTERNATIONAL...
UNUSED LANDHONOR MPF-11-2000G PALLET FORKS FRAME (A54757)
UNUSED LANDHONOR...
2008 DRAGON 150 BBL ALUMINUM VACUUM TRAILER (A53843)
2008 DRAGON 150...
2019 Kia Soul SUV (A55758)
2019 Kia Soul SUV...
