ZTR ZFORCE 42 - can I add a hitch for tow behind?
   / ZTR ZFORCE 42 - can I add a hitch for tow behind? #1
chalfant
To my surprise the ZFORCE 42 doesn't have a hitch. Is there some sort of kit that I can purchase to use tow behind implements like a broadcast spreader?
Are the tow behind spreaders even worth the effort?
Thanks,
Chris
   / ZTR ZFORCE 42 - can I add a hitch for tow behind? #2
I had an "Agri-Fab" tow behind broadcast spreader. It ended up out at the curb with the trash after one season. The mechanism corroded so badly that the drive wheels locked up. I figured it was a fluke so when I wanted a tow behind lawn sweeper/catcher I found an "Agri-Fab" unit I thought looked pretty good. Bought it. It lasted less than one season before it went to the dump.
So my experience is, do not buy an Agri-Fab brand anything.
As for a tow hitch, you might be able to buy a heavy duty EYE BOLT (stainless or zinc plated to prevent rust), something like a 3/8" size and some lock nuts and a couple washers. Then simply drill a 3/8" hole somewhere on the back of the ZForce unit and install the eye bolt. There are lots of different qualities of hardware, I would strongly suggest heavy zinc plating or stainless steel. It might cost a couple bucks instead of 50-cents, but it will last forever. Also, when you drill the hole, make sure to spray in some automotive primer over the newly exposed bare metal and then touch it up with some Cub Cadet yellow paint to prevent any rust from starting at the hole. 5 extra minutes, and $3.50 worth of paint, will prevent a ton of problems a few years from now.
Where can one purchase cub cadet touch up paint?
Secondly, there are two holes on the back bar of the ZForce, it seems like they out to seal something that mounts directly to those two bolts. Would a broadcast spreader be too much stress on this beam? Or should I just push my fertilizer. Actually I wonder if it makes more of a mess and isn't good for fertilizer or grass seed to get all over the engine.
Adams FL24 Fertilizer Conveyor - 24IN Belt, Predator Engine, 2IN Hitch, Refurbished by Manufacturer (A52128)
Adams FL24...
2006 Freightliner Business Class M2 Beverage Truck (A47384)
2006 Freightliner...
UNUSED FUTURE SKID STEER SIDE SHIFT FORKS (A51244)
UNUSED FUTURE SKID...
UNUSED AGT DM20 EXCAVATOR (A51243)
UNUSED AGT DM20...
2011 Manac 36245B30 43ft T/A Walking Floor Trailer (A50322)
2011 Manac...
2012 Ford F450 Bucket Truck (A50323)
2012 Ford F450...
