ZTR ZFORCE 42 - can I add a hitch for tow behind?
   / ZTR ZFORCE 42 - can I add a hitch for tow behind? #1
chalfant
To my surprise the ZFORCE 42 doesn't have a hitch. Is there some sort of kit that I can purchase to use tow behind implements like a broadcast spreader?
Are the tow behind spreaders even worth the effort?
Thanks,
Chris
   / ZTR ZFORCE 42 - can I add a hitch for tow behind? #2
I had an "Agri-Fab" tow behind broadcast spreader. It ended up out at the curb with the trash after one season. The mechanism corroded so badly that the drive wheels locked up. I figured it was a fluke so when I wanted a tow behind lawn sweeper/catcher I found an "Agri-Fab" unit I thought looked pretty good. Bought it. It lasted less than one season before it went to the dump.
So my experience is, do not buy an Agri-Fab brand anything.
As for a tow hitch, you might be able to buy a heavy duty EYE BOLT (stainless or zinc plated to prevent rust), something like a 3/8" size and some lock nuts and a couple washers. Then simply drill a 3/8" hole somewhere on the back of the ZForce unit and install the eye bolt. There are lots of different qualities of hardware, I would strongly suggest heavy zinc plating or stainless steel. It might cost a couple bucks instead of 50-cents, but it will last forever. Also, when you drill the hole, make sure to spray in some automotive primer over the newly exposed bare metal and then touch it up with some Cub Cadet yellow paint to prevent any rust from starting at the hole. 5 extra minutes, and $3.50 worth of paint, will prevent a ton of problems a few years from now.
Where can one purchase cub cadet touch up paint?
Secondly, there are two holes on the back bar of the ZForce, it seems like they out to seal something that mounts directly to those two bolts. Would a broadcast spreader be too much stress on this beam? Or should I just push my fertilizer. Actually I wonder if it makes more of a mess and isn't good for fertilizer or grass seed to get all over the engine.
2018 Ford Transit 250 Cargo Van (A48081)
2018 Ford Transit...
2018 Toro Groundsmaster 7200 72in Zero Turn Mower (A48082)
2018 Toro...
12 FLATBED W/ PRESSURE WASHER FRAME (A50854)
12 FLATBED W/...
2008 Ford F-250 Service Truck with Liftgate (A48081)
2008 Ford F-250...
2016 Ford Explorer AWD SUV (A48082)
2016 Ford Explorer...
2016 John Deere 35G Mini Excavator (A49461)
2016 John Deere...
