ZTR Mower Engine Surging and Dying
   / ZTR Mower Engine Surging and Dying #1
ky8t
On Lake Livinston in Texas
Kubota BX-2230
My John Deere ZTR mower, which has less than 10 hours on it, has started acting up. After mowing for maybe 10-15 minutes, the engine starts surging like it is gasping for fuel. Then it dies. After I wait 10 minutes or so, it starts back up and after another 10-15 minutes surges and dies again. Any ideas what the problem might be?
   / ZTR Mower Engine Surging and Dying #2
What kind of engine, make/model, HP, etc.
   / ZTR Mower Engine Surging and Dying #3
Take the gas cap off and see if it still surges and dies?
That seems to fix the problem. What would cause that? I assume leaving the gas cap loose is not a permanent fix.
   / ZTR Mower Engine Surging and Dying #6
There is supposed to be a hole or some kind of relief to let air in so fuel can flow. It may be a hole in the cap. or a slit in the thread area. or a small rubber plug . The hole may have rusted shut.
I'll check that out. Hope I don't have a mud dauber wasp nest on it somewhere. My barn is filled with them.
   / ZTR Mower Engine Surging and Dying #8
There is a little rubber flap in the top of the cap that lets in air but doesn't let it escape to the atmosphere. This is likeley your culpret. Clean with a non alcohol base cleaner and you should be good. Worse case replace the fuel cap. You should be able to blow through the little hole in the top center of the gas cap. Good luck!
I am mowing a new lawn, and there is a lot of dust. I bet that dust was sucked into the vent hole. Thanks for the tip.
   / ZTR Mower Engine Surging and Dying #10
No problem hope that gets you mowing again.
2012 VOLVO BL70B BACKHOE LOADER (A51406)
2012 VOLVO BL70B...
Manac Walking Floor Trailer (A50322)
Manac Walking...
2015 JLG Triple-L Flatbed T/A Trailer (A50324)
2015 JLG Triple-L...
2009 40ft High Cube Refrigerated Storage Container (A51692)
2009 40ft High...
2014 Peterbilt 384 T/A Wet Kit Day Cab Truck Tractor (A51692)
2014 Peterbilt 384...
2022 Gravely Pro-Turn 600 Zero-Turn Mower with 72-Inch X-Factor 3 Deck (A55218)
2022 Gravely...
