ZTR handling Question
   / ZTR handling Question #1
theplayer
I have a question is regards to my new Ferris 1500. It seems that the left handle is not as responsive as the right. When I move the right handle, the response is immediate, but when I move the left, it doesn't appear that the machine is as quick to respond.
Is this a simple handle adjustment or could the problem be something else? I'm not 100% on this, but it also seems like the motor is working harder(louder) when I use the left handle.
   / ZTR handling Question #2
Since it's new, have you called your dealer? Seems like there might be an adjustment needed...........
   / ZTR handling Question #3
player, It is more than likely an adjustment , Mine was out a hair when I first used it , Half hour later it was fine after a slight ajustment.... /forums/images/graemlins/cool.gif
The steering lever is attached to the pump via a turnbuckle style connection ,Thats where I made my ajustments, Really no need to get dealer involved in that one, IMO that is /forums/images/graemlins/smile.gif
   / ZTR handling Question #4
theplayer,
My Ferris IS 3000 does the same thing, I mentioned it to the dealer and there response was one side will always be a little stonger than the other side. Kind of mimicks our own bodies. If it is signficant take it back to the dealer for adjustment.
db
2021 International HV507 4x4 12ft Single Axle Dump Truck (A51692)
2021 International...
2008 Genie S-65 65ft Telescoping Boom Lift (A53421)
2008 Genie S-65...
Earthquake RotoTiller (A53117)
Earthquake...
1994 MACK RD688S BOBTAIL VACUUM TRUCK (A53843)
1994 MACK RD688S...
YANMAR ViO45-5 EXCAVATOR (A51406)
YANMAR ViO45-5...
UNUSED CFG INDUSTRIAL H15R EXCAVATOR (A52706)
UNUSED CFG...
