ZTR Choices
   / ZTR Choices #1
renegade13
Calgary, Alberta, Canada
Hello,
After doing some soul searching, I've pretty much decided on getting a ZTR mower for my 3.5 acres of grass instead of a sub-compact. I've looked around locally and have found the following options:
1. Used 2000 JD F620, 20 HP, 54" deck, asking $6,500 CDN - only 220 hours and looks to be in almost perfect shape
2. Brand New Exmark Quest, 24 HP, 52" deck, $5,250 CDN
Which is a better option? Any advice would be appreciated.
Thanks.
   / ZTR Choices #2
I have an '01 F620 with a 60'' 7-iron deck. Couldn't be happier with it. Very stable on hills. I bought mine with 120 hrs on it and had been used 2 seasons. Paid $7,900 for it in '03 as a comparison. Listed for $13,000 CDN new - overpriced if you ask me.
It has the optional twin rear caster wheels, instead of the single wheel.
The F620 can flip the deck up 90 degrees for cleaning.
Not sure about the Exmark
The Exmark is the more current style of ZTR where you sit in front of the engine instead of over it. I would suspect the JD has a lower C of G.
Personally, in this situation I would lean towards the Exmark. It's new - with warranty. The price on it seems reasonable for a new unit.
   / ZTR Choices #3
I bought a used 2004 Hustler Super Z, 27hp Koehler, 60" two years back with 50hrs for $5300. It had one scratch on the side of the deck and was missing a knob ($4) for access to one of the deck pulleys. It has been a great machine and I highly recommend looking at one. If I recall they are owned by John Deere and are marketed for commercial applications. My John Deere dealer carries Hustler.
I think there are a lot of really good ZTRs on the market but, one thing to really look at, which is sort of a measurement of quality for me, is deck construction. In my opinion all decks should be welded and not stamped.
   / ZTR Choices
Hello,
Thanks.
Hello,
I just found one more option:
Used 2008 JD Z520A, 25 HP, 54" deck, asking $6,500 CDN - only 30 hours and under warranty until May 2010
This seems to be a better deal than the F620 but I may be wrong.
   / ZTR Choices #5
I purchased a new Exmark Laser Z 60" June 07. I can say that it is a great mower for the buck. I'm very impressed with the quality of it's construction. I feel it's worth going with the new purchase for many reasons.
Good luck
   / ZTR Choices #6
I spent a few months looking at them before going with Scag. If you have a dealer for them, it's worth your time to take a look.
Eddie
   / ZTR Choices #7
I second the Scag. In the last few months that I had been deciding on what to get for a new grass cutter, the scag was the only zero turn that I felt was worth giving my money for.
   / ZTR Choices #8
I have a residential mower Country Clipper Jazee 1 for my three acres with a 42" deck. I needed the samll deck to get into some of the tight spots. From my research, the Exmarks and Scags have the best reputation around here.
   / ZTR Choices #9
I have a Lawn mantainance company and I found that Ferris & Scag are the top of the line. But since you have a choice between a JD & an Exmark,I would choose the barely used John Deere. GOD Bless P.S. I just saw that you had another choice. Go with your heart on this one.
   / ZTR Choices #10
Come to think of it, the 2008 JD with the warranty till 2010 is probably the way to go.
JOHN DEERE 2350 TRACTOR (A54756)
JOHN DEERE 2350...
Case 1150G Crawler Tractor Dozer (A53421)
Case 1150G Crawler...
2015 SkyJack SJ86T 4x4 86ft Telescopic Boom Lift (A52377)
2015 SkyJack SJ86T...
CAT CS563 (A47477)
CAT CS563 (A47477)
KUBOTA RTV X1100C UTV (A51406)
KUBOTA RTV X1100C...
2012 VOLVO EC300DL EXCAVATOR (A51406)
2012 VOLVO EC300DL...
