zip tie tire chains
   / zip tie tire chains #1
wldrbob
Bronze Member
swan river manitoba canada
white 2/60 case 830 w4 international cletrac cat
i saw these on youtube and thought i would tell you what i have used for traction aids for years a piece of light chain and a carabiner and apiece of wire ,, feed the wire and attached chain through your spokes on your drive wheel wrap around tire and hook up carabiner sometimes i use just one on a tire but i usaly put 3 on each easy to put on and easy to take off after your out of the snowbank or mud hole.. 25 bucks for the chain and carabiners and reusable many times.. 13 to 15 or more for the zip grip system and not reusable a lot cheaper than a tow but i will stick with my cheap chain system
   / zip tie tire chains #3
seen them and thought that is OK for a short stuck spot but if there are not a "Remove" tab on them then the cost would not be an issue IF they were reusable a few times. I think cost was OK and light enough to carry in trunk of a regular car... ONLY low speed for a small distance.
Mark
2021 M&J PRESHRED 4000M SHREDDER (A53426)
2021 M&J PRESHRED...
2023 JOHN DEERE 333G LOT IDENTIFIER 203 (A53084)
2023 JOHN DEERE...
2001 J ODell 16ft Enclosed T/A Trailer (A51691)
2001 J ODell 16ft...
2022 JOHN DEERE 331G LOT NUMBER 96 (A53084)
2022 JOHN DEERE...
UNUSED INDUSTRIAS AMERICA HI-900 HYD LAND LEVELER (A51247)
UNUSED INDUSTRIAS...
2014 Ford Escape SUV (A51694)
2014 Ford Escape...
