ZForce Tire Woes
/ ZForce Tire Woes #1
Florida_Farmer
Central Florida
841 Powermaster, TC33D, TC40 DA, Yanmar 1500, Yanmar 2210B, Scag Turf Tiger, Exmark 72" Lazer Z
I've got a 2004 ZForce mower - this year I replaced the front tires with never flats and had tubes on the back tires - thinking I'm good but ran over a broken bottle mowing and a I'm rewarded with a flat back tire. Tire size is 18x9.5-8. The old tire is dry-rotted and I was too tired to wrestle with an inner tube so off to Tractor Supply to buy a new 18" rear wheel and tire for 70 bucks. Part# 634-04128.
Brought it home, bolted it on and off to mow. 5 minutes later that tire blows out. Turns out the offset on the rim is different so the tire is catching the frame I guess when bouncing over bumps and flexing out. Also damaged my right side brake cable beyond repair.
I get on the phone with MTD to let them know the label on the tire says it fits all the Zero Turn Mowers but after giving her my serial number - she confirms my wheel is different and that also my wheel is showing as no longer available. I said I was taking the tire back to Tractor Supply but needed a new brake cable from them and also for them to change their product label so the next guy like me doesn't have the same problem. They sent me a new brake cable at no-charge and said to call back if I have any issue returning the wheel to Tractor Supply. The cable shipped the same day.
While I was not happy about the damage, I was glad to talk to a nice lady who spoke perfect English from Ohio - not some call center offshore who was ready and able to do the best she could to make things right.
Moral to the story is be careful with rim offset - not all are the same and it's great to see there is some good customer service left.
Also - called my local mower repair guy to check if he had a tube - mower was a few acres away and I wanted to get it back inside - he said pull a tire off your golf cart and drive it home. it worked!
Rhino 7.5ft Rotary Mower (A64127)
Rhino 7.5ft Rotary...
2008 PETERBILT 365 (A65643)
2008 PETERBILT 365...
Landhonor MPF-11-2000G Skid Steer Pallet Forks  (A62679)
Landhonor...
20' Reids Trailer (A62613)
20' Reids Trailer...
2000 Bobcat 863 High Flow Compact Wheel Loader Skid Steer (A59228)
2000 Bobcat 863...
2015 CASE CX160C EXCAVATOR (A65053)
2015 CASE CX160C...
