zetor 7745 hydrualics not working
   / zetor 7745 hydrualics not working #1
cjjans89
zetor 7745
I have a zetor 7745 and I can't seen to get the hydraulic working for the loader or three point hitch when It worked fine when I used it a month ago so I don't know if I have the lever wrong or what any help would b appreciated thanks
   / zetor 7745 hydrualics not working #2
Try moving the 3pt lever, and see if it affect the FEL.
Install a gage in the system before the first valve.
ok i tried that and nothing what do you mean by putting a guage on there is it so i can see if its working or for something else and i dint know if you know a lot about this tractor but there is a lever on the floor that runs everything and i think it has 4 positions and that is what i was think i had wrong but i tried all of them and i cant get it going
   / zetor 7745 hydrualics not working #4
Yes, a gage will tell you if you have pressure, and how much. It can also be used to set relief valves.
well i will def have to do that then when i get it home from the farm is there anything else u may know abouty the hydrualics and why they are not working and thanks for the info
   / zetor 7745 hydrualics not working #6
Can you see the pump? Does it have coupling connector from pump to crank shaft? I assume not out of oil? Can you hear fluid moving through valve or hose?
Miller Millermatic 25 Welder, SKU# 907321, S/N MJ260223N, Rated Output-Amperage 200 (A59076)
Miller Millermatic...
John Deere 6ft (A56857)
John Deere 6ft...
2019 Freightliner M2 106 AWD Altec AA55 56ft. Insulated Material Handling Bucket Truck (A55973)
2019 Freightliner...
2009 INTERNATIONAL DURASTAR 4300 SBA ROAD TRACTOR (A58375)
2009 INTERNATIONAL...
SHOP MADE MANIFOLD TRAILER (A58214)
SHOP MADE MANIFOLD...
1288 (A58374)
1288 (A58374)
