Zetor 7341
/ Zetor 7341 #1
yooperdave
Marinette, WI
Tool Cat 5600, LS XJ2025H, Branson 4215HC
Does a Zetor 7341 with cab & loader for $32,000 sound like a good deal? The top of cab is 9' above the ground. My overhead door is also only 9' high. I guess I am going cabless /forums/images/graemlins/frown.gif.
http://www.upcars.com/private/356651b.html
or
I could also get a 4341 (approx 55 pto hp) with loader and no cab for $22,000.
Yooper Dave
/ Zetor 7341 #2
yooperdave
Both tractors are excellent. Ever thought of raising that garage door. You would really enjoy that cab. With either one you will "be better with a Zetor"
Good luck
Chipperman
/ Zetor 7341
My overhead garage door is less than a week old /forums/images/graemlins/shocked.gif!
My uncle has a few old Olivers with cabs and they are well below 9' high. So when it came time to build, I thought having an extra foot would really open things up.
I guess the 4341 with cab would be closer to 8'-8" high with the ag tires. I am going to take another measurement on the door.
Yooper Dave
/ Zetor 7341 #4
Dave, I don't know about the 7341, but I was quoted $21,450 on a 4341 with loader last year. However, the dealer only had the tractor and did not know when a loader would be shipped. Since then he has gone out of business and another local dealer has taken up the Zetor line and dropped Valtra. I was really impressed with the 4341, but went with the Mahindra, ROPS height would not have fit into my existing tractor shed on the 4341. That was not the only reason, dealer and 0% financing played a big part in my decision. But I really did like the tractor. Chet
/ Zetor 7341
Hi Chet,
Which Mahindra did you feel was similar to the 4341?
I am guessing the 6000.
Were the prices and features similar also? I thought that the Zetor was the best bang for the buck for a full sized Ag tractor.
I am supposed to be getting some Zetor literature in the mail soon.
Yooper Dave
/ Zetor 7341 #6
yooperdave
I wood be very interested in how the 6000 compares in price. The Zetor is more tractor but the 6000 is probably Mahindra's closest model. Also I don't think there is a cab for the 6000. I checked the specs on the 7341.1SR and the 4341.1SR (Cab unit) and they are 104 and 102 respectively. Therefore they should fit through your 108" door. For what ever it is worth if it will fit and you can afford it the Zetor cab with heat and air is wonderful.
Good luck
Chipperman
/ Zetor 7341
Hi Chipperman,
What does a cab cost, and what exactly do you get for it?
I would assume that there would be a quiet climate controlled environment. Is there a radio? Does it rob any of the engine horsepower? Does the cab get in the way of anything?
Thanks
Yooper Dave
/ Zetor 7341 #8
yooperdave
</font><font color="blue" class="small">( What does a cab cost, and what exactly do you get for it? )</font>
At list price $6000+-. The deck on the cab units are completely flat where as the open station units have a 4 to 6 inck tunnel.
</font><font color="blue" class="small">( I would assume that there would be a quiet climate controlled environment. )</font>
Yes.
</font><font color="blue" class="small">( Is there a radio? )</font>
No but it is wired for it and some have speakers installed.
</font><font color="blue" class="small">( Does it rob any of the engine horsepower?)</font>
The cab does not but the air does use a small amount. (I would not be concerned about it.)
</font><font color="blue" class="small">( Does the cab get in the way of anything?)</font>
Not that I can think of.
Hope that helps
Good luck
Chipperman
/ Zetor 7341 #9
Just be carefull, these tractors have high centre of gravity, if you have slopes. /forums/images/graemlins/wink.gif
/ Zetor 7341 #10
ZJ_HR
Don't take this the wrong way but, what data do you have to back up that statement when comparing to other cab or non cab tractors in the same wieght class.
Chipperman
/ Zetor 7341 #11
From every tractors here, allmost half of them are Zetors. A relative has 6211 with cab, and had it turned over few times. They are good on flat terrain, as Czech Republic is, but be carefull on slopes. That was reason why people in hills not buy them, and buy Universal (or Longtrac therein US) instead of it. Idea of my reply was just warning, and not to be critic to brand choice.
/ Zetor 7341 #12
Around here the 6000 would be closest in price and horsepower, which was more tracor than I need and more money than I wanted to spend, so I went with the 4500. Chet
/ Zetor 7341 #13
ZJ_HR
The 6211 is no longer available in the states. I am not familiar with it. If the wheels are loaded and set in the outboard position they are quite stable. Yes, some tractors will do better on severe slopes but set up properly the Zetor is very stable. Sorry to hear your relative turned his over. I do not think Landtrac currently has a comparable tractor to the 4341 in the states.
Thanks
Chipperman
/ Zetor 7341 #14
Chipperman,
Here nobody uses loaded tires. Even for plowing. Maybe rear wheels weights, sometimes.
Good hydraulic system can add enough load to rear axle for plowing.
As we have narrow field roads, sometimes looking like a canyons, in 99% of cases 1410mm (55 1/2 in) rear wheels track is used (factory settings).
I know that UTB (Landtrac) can't be compared to x21/41 series, but we haven't a lot of this Zetor models here.
Price difference is too big for what they offer, so people buy more x20/40 series. I don't know how tractors are equipped there, but here x21/41 just have 540rpm PTO, no reverser, no A/C.
Most popular UTB model is Universal 643DTC, equipped with insulated cab and heating, like Zetor models. Cab is narrower and about 10-12" lower than on Zetor models.
Most popular Zetor models are 4320/40 and 6340.
Personally I prefer lower tractors, like NH TN(D) series. They have lower positioned seat, and are more pleasant for ride on bumpy terrain (because of lower left-to-right seat moving).
I like cab design of new x21/41 Zetor, similar to Fortterra series.
Anyway, Zetor is good choice, I think, as are many other brands, too.
Just look carefully for all advantages and disadvantages, and try it before purchase.
/ Zetor 7341 #16
In Croatia. South Europe.
You are Zetor dealer?
New/Unused Landhonor Hand Chain Hoist (A65583)
New/Unused...
Adams Tender / Magnolia Trailer (A61307)
Adams Tender /...
Gehl Mix-All Grinder Mixer (A66408)
Gehl Mix-All...
case 370 glass door never installed (A61307)
case 370 glass...
(INOP)1989 NISSAN D21 EXTENDED CAB TRUCK (A64280)
(INOP)1989 NISSAN...
2025 Unused SDLGC80 Electric Golf Cart (A64194)
2025 Unused...
