Zetor 6441 Not starting
   / Zetor 6441 Not starting #1
jeb787
Zetor 6441
My Zetor had a new battery installed back in January. This tractor isn't used much but is run every 2 weeks. Was last used to lift a few t-posts out of the ground, not any real work. Was parked as normal but now won't start. The dealer wasn't much of help over the phone. When you go to start, the glow plug light starts as normal and the oil light comes on as normal, but it doesn't attempt anything after that. when you turn the key, nothing. Seems like it's not even getting the signal to turn over. Normally it shows a battery light and charging light when you go to start it. the lights all stay on till it's warm then all the lights go off. but the battery light and charging light aren't lighting up to crank possibly because it's not cranking. Nothing in the owner's manual shows any safety sensors to check. It's behaving as if a relay isn't working, but i cant find any to know where to start.
   / Zetor 6441 Not starting #2
I've got a Zetor 8441. I have to lift slightly on the PTO clutch handle in order to start it. The owner's manual refers to it as a safety switch. If I forget to lift the handle, it acts exactly as you describe.
Greg
   / Zetor 6441 Not starting #3
It does sound like one of the safety switches is not being satisfied. Different tractors have different safeties. You may need to check the PTO as suggested but there may also be a seat switch, a neutral switch, and a clutch switch. Check your manual to see what's what.
Greg
Yup same for mine. Ill look into if it has a safety in the handle too. thank you
2016 FORD EXPLORER (A51406)
2016 FORD EXPLORER...
BE Quick Attach Snow Blade (A50514)
BE Quick Attach...
2018 Toyota RAV4 Hybrid XLE AWD SUV (A50324)
2018 Toyota RAV4...
2018 GENIE GTH-5519 TELESCOPIC FORKLIFT (A51242)
2018 GENIE...
Informational Lot - Shipping (A52128)
Informational Lot...
Case 580D (A47384)
Case 580D (A47384)
