Zetor 6245 Wiring
   / Zetor 6245 Wiring #1
darrensmith
Does anybody know the correct connections for changing the old round 5 pin flasher relay to the newer 6 pin square? Some of the numbers on the new relay are the same as the old but matching these up does not work? So I need to know which colour goes to which number...
If anyone can tell me where I can get a wiring diagram for a Zetor 6245 that would be great also. /forums/images/graemlins/confused.gif
   / Zetor 6245 Wiring #2
darrensmith
Hello, Might I suggest you ask your local dealer? Where are you located? I would think if all else fails Peter should be able to help you. You can reach him at 888-357-5105. Press number 2 and leave him a message. He will get back to you.
Thanks and Happy Tractoring
Chipperman
PS: for any one up in central NY state. Come visit us at the Boonville forestry days. It runs through tomorrow
   / Zetor 6245 Wiring
Chipperman,
I am based in the UK and our dealers tend to supply parts based on you know what you are doing or book the tractor into their workshop and they will fix the problem! $$$
Anyway I have found the answer from another forum so will post the answer here in case anyone else has the problem.
Old round flasher is bimetal type, and new one is electronic. Electronic flashers need ground connection, when bimetal ones don't.
Here is description of numbers/letters on flasher unit, and their meaning.
49 - supply
49a - outgoing, towards direction switch
C - signal lamp for tractor direction light
C2 - signal lamp for first trailor direction light
C3 - signal lamp for second trailor direction light
31 - ground
You need to connect the ground, and it will work. Ground connection can be on ear (if it is metal) where is fixing point.
Landoll Hauloll (A53472)
Landoll Hauloll...
2016 Kia Cadenza Sedan (A51694)
2016 Kia Cadenza...
2023 Globe Booster Flipaxle (A51572)
2023 Globe Booster...
Caterpillar Loader Quick Coupler (A53472)
Caterpillar Loader...
2004 MCI D4500 Passenger Bus, VIN # 1M8PDMPA54P056247 (A51572)
2004 MCI D4500...
12ft Godwin Dump Body/Bed (A51573)
12ft Godwin Dump...
